Replaced wheel bearings... still rubbing noise...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Toy Coma, Nov 5, 2016.
  1. Nov 5, 2016 at 7:34 AM
    Toy Coma
    Toy Coma [OP] Well-Known Member
    Dallas TX
    2006 TRD Sport 4x4
    Icon Coil over lift, SPC UCA, Wheelers AAL & Bump stops Relentless fab rear bumper, AVID Sliders, Statoshi Grille Mod, Morimoto LED fogs, Ebay Headlights W/Halos Core Short Throw Shifter, mesojdm Ultimate LED pods. Cali raised ditch light brackets 17" SCS Ray 10 brushed Copper Wrapped in 295/75/17 General Grabbers Wilco prerunner style Tire gate ATH off road front bumper
    I recently purchased wheel bearings and hubs assembly from bamaToy... Everything went in great however i still have the "bad wheel bearing" noise... coming from front passenger side... Not sure what else it could be....
    Any help or idea's are appreciated
  2. Nov 5, 2016 at 7:36 AM
    Pigpen
    Dan
    Northwest Montana
    does it go away in 4wd?
  3. Nov 5, 2016 at 7:48 AM
    Toy Coma
    Dallas TX
    2006 TRD Sport 4x4
    No it doesnt matter 2 or 4wd
  4. Nov 5, 2016 at 7:51 AM
    Pigpen
    Dan
    Northwest Montana
    That doesn't necessarily rule out the driver side diff bearing...are yo 100% positive it's coming from the passenger side? Or does it just sound that way from the driver's seat?
  5. Nov 5, 2016 at 7:54 AM
    Toy Coma
    Dallas TX
    2006 TRD Sport 4x4
    Definitely, sounds like passenger side.... and still acts like a wheel bearing noise.... goes quiet when turning left ect ect
  6. Nov 5, 2016 at 7:57 AM
    deeezy
    deeezy Well-Known Member
    Dana
    Hawaii
    2013 4x4 DC, 6 spd, TRD Sport
    King ext travel coilovers, Icon tubular UCA's Rear-King "Tundra" 2.5's, Allpro Expos, TRD cat-back, Hurst/Core short shift kit, etc...
    If it goes quiet when turning left, it's most likely your driver's side. When turning left, you are unloading the driver's side and the weight of the truck transfers over to the passenger.
    edit: nevermind, you changed both wheel bearings, correct?
    Davtopgun likes this.
  7. Nov 5, 2016 at 7:59 AM
    Davtopgun
    Davtopgun Weeeee mod time!
    David
    Central Alabama
    2018 Tundra Platinum
    6112/5160 35" Toyo Open country
    Did you replace both sides, or just the passanger?
  8. Nov 5, 2016 at 8:05 AM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Make sure your dust shield isn't dragging on your rotor before going berserker on tearing everything apart.
  9. Nov 5, 2016 at 8:06 AM
    Pigpen
    Dan
    Northwest Montana
    Have you replaced the diff bearing? In ten years it may have reached the point where you hear it in 4x4 too. I thought mine was a passenger side vibe at first.
    doorsidedown likes this.
  10. Nov 5, 2016 at 8:07 AM
    Toy Coma
    Dallas TX
    2006 TRD Sport 4x4
    My bad i mi spoke... it goes away when turning to the right.. not left... I only replaced the passenger side. Since it was giving all indications it was that side...
  11. Nov 5, 2016 at 8:08 AM
    Toy Coma
    Dallas TX
    2006 TRD Sport 4x4
    No i have not changed the Differential bearing..
  12. Nov 5, 2016 at 8:15 AM
    Davtopgun
    David
    Central Alabama
    Considering the price of wheel bearings, I would go the cheapest route first.
    You can replace your needle bearing yourself for about $40. If that doesn't work, it's likely your other wheel bearing.
  13. Nov 5, 2016 at 8:16 AM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    I kinda treat wheel bearings like radiator hoses or wiper blades...if one is bad, replace both, since they have the same age and mileage on them, so If one has gone bad, the other isn't too far behind.
  14. Nov 5, 2016 at 8:25 AM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    The driver side wheel bearing is the most common bad bearing. Change that first then look at the diff bearing.
  15. Nov 5, 2016 at 8:30 AM
    Toy Coma
    Dallas TX
    2006 TRD Sport 4x4
    Thanks for all the advice looks like i have a few things to check on
  16. Nov 5, 2016 at 8:36 AM
    timothom
    timothom Well-Known Member
    2014 Tacoma Access cab sr5
    Kenwood DMX7705S PrecisionPower Phantom 900.4 Alpine type-r 8" Image Dyanmics CXS64.2
    You sure it's not a mis-aligned brake caliper causing a brake pad to drag?
  17. Nov 9, 2016 at 4:54 AM
    Toy Coma
    Dallas TX
    2006 TRD Sport 4x4
    those two things sounds totally different....
  18. Nov 9, 2016 at 6:31 AM
    brierpath
    brierpath New Member
    Bill
    2007 PreRunner double cab
    K&N, nerf bars
    Just replaced my driver's side bearing at 110K. Thought it was tire noise till it quieted when changing lanes to the right. Only one of the bearing races was trashed inside it when disassembled.
  19. Nov 14, 2016 at 12:06 PM
    Toy Coma
    Dallas TX
    2006 TRD Sport 4x4
    It was the drivers side bearing even though ll indications pointed to passenger again.. Time to order another hub from Jerseyhubs thanks all for the quick replies!!!
