Replacement aluminum oil filter cap assembly for 3.5 V6
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joisey, Jul 28, 2018.
  1. Jul 28, 2018 at 6:35 PM
    Joisey
    Joisey [OP] Well-Known Member
    Does anyone know if the Toyota aluminum oil filter cap # 15620-31060 can be used to replace the plastic unit on my 2018 Toyota Tacoma 3.5 V6?
    I find conflicting information online. Thank you for the help.
  2. Jul 28, 2018 at 6:47 PM
    4x4_Taco
    4x4_Taco Well-Known Member
    FL
    Silver SR5 4x4
    Why change? The oil filter housing is up high and covered by the skid plate.
  3. Jul 28, 2018 at 6:54 PM
    Joisey
    I trust cast aluminum a lot more than plastic when it come to hot oil under pressure.
    Chuy and Mr-Paul like this.
  4. Jul 28, 2018 at 6:55 PM
    Joisey
    Do you know where the small leaks were from? The drain plug or the filter housing O ring sealing?
  5. Jul 28, 2018 at 7:09 PM
    Joisey
    Thank you for your help. As I wrote before, I trust cast aluminum more than plastic when heat and pressure are present.
    Vbpiper likes this.
  6. Jul 28, 2018 at 7:15 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    It does, indeed. I found one off Amazon for about $16 shipped.
    Vbpiper likes this.
  7. Jul 28, 2018 at 7:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    There have been zero problems due to heat or pressure on the OEM housing after close to a half million 3rd gens sold in three years. Don't worry.
    4x4_Taco and shakerhood like this.
  8. Jul 28, 2018 at 7:30 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Oh there have been problems, just not with that particular piece lol. When we are designing our hydraulic systems we would much rather use plastic wherever possible. Much less headache and much more impact resistant.
    Vbpiper likes this.
  9. Jul 28, 2018 at 8:56 PM
    NC_Pinz
    NC_Pinz Well-Known Member
    North Carolina
    2018 Cavalry Blue TRD Pro
    Had a composite housing on my 2010 FJ and have had no issues. Composite material works just fine in heat and under pressure.
  10. Jul 29, 2018 at 8:08 AM
    Shellshock
    Iowa
    I swapped mine. No issues since.
  11. Jul 29, 2018 at 8:27 AM
    S0ju
    S0ju Well-Known Member
    Norcal
    2018 mgm dclb sr5
    If it's the same material as the OEM scion frs filters you'll be fine. Doubt the tacoma will ever get as hot as tracking a car in 100+*f heat.
  12. Jul 29, 2018 at 8:31 AM
    Bishop84
    Bishop84 Well-Known Member
    The plastic on the canister caps distorts, especially when tightened by lube bay kids. It's not a spin on filter.
  13. Jul 29, 2018 at 8:40 AM
    S0ju
    Norcal
    2018 mgm dclb sr5
    Oh didn't know that. Good to know, thanks
  14. Jul 29, 2018 at 11:00 AM
    maileboy
    maileboy Well-Known Member
    David
    Mt. View (Big Island) but from Maili
    2017 TRD OFF-ROAD 4dr 3.5-auto, Magnetic Grey
    To OP, I thought I had a leak when installed mine but but it was residual from install. Just checked other day after couple months of use..."..
