Replacement battery - AGM or?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by drewstaco, Jan 16, 2025.
  1. Jan 17, 2025 at 4:16 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    What is this Canadian English you speak of??? :ohsnap:
  2. Jan 17, 2025 at 4:35 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I didn't ay "Canadian English", I said "English or Canadian".
    I see your from Ottawa. At least your avatar says so. If there are any strange twists it comes from there ha ha.
    Every country that uses old English as their base language has their nuances and colloquialisms.
    USA too.
    Thanks eh.
    Tocamo[QUOTED] likes this.
  3. Jan 17, 2025 at 5:37 PM
    LACO Taco
    LACO Taco Active Member
    I've been running an AGM for over 3 years with no issues - I didnt even know about the ECU flash stuff, I have a ton of lighting, winch, compressor, Redarc system to my Lithium setup - you name it. I'm running the X2Power one.
    shakerhood likes this.
  4. Jan 17, 2025 at 5:51 PM
    GTGallop
    GTGallop Well-Known Member
    Greg
    Anthem, Arizona
    2023 Magnetic Grey TRD-OR 4x4
    Dash Cams and Hams!
    There's a bunch of these threads here. Hard to find with the search but if you go to google.com and type TacomaWorld.com and then your term like battery it works really well.
    On one of these threads a guy recommended a CAT battery by caterpillar. More heat resistant apparently. It's on my radar in 14 months when mine dies.
  5. Jan 17, 2025 at 6:51 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    In my experience, which involves maintaining batteries used in high vibration and harsh environments, flooded batteries are more reliable. Unless an AGM is specifically required due to the battery becoming inverted in use, a flooded is a more reliable option, with longer lifespan. So unless you plan on rolling your Tacoma, a good quality flooded battery will serve you better for longer.
  6. Jan 18, 2025 at 8:12 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    Flooded is vented and vented means flooding your engine bay with acid if you spend time off road on washboard or other non-first world expressways. Of course, YMMV.
    ToyodaSun and GTGallop like this.
  7. Jan 18, 2025 at 9:19 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    :cookiemonster:
  8. Jan 18, 2025 at 9:37 AM
    tacofish
    tacofish Well-Known Member
    N NJ
    14 ext cab 4x4
    3/1 lowrange spacer lift 285/70/17 wildpeaks
    Just replaced mine this morning
    Had an ac delco 2yr that lasted 5yrs
    Went with the 3yr this time
    Don’t really have an option on which brand is best, i just go with what nearest auto store has in stock
    Tocamo likes this.
