Replacement brake line clamp for Icon RXTs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hook78, May 12, 2022.
  1. May 15, 2022 at 6:56 AM
    Hook78
    Hook78 [OP] Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    See thread title…
    My setup looks just like the pics that have been posted except I have slightly less slack and can’t bolt the guide up that high.
    NmapFE[QUOTED] likes this.
  2. May 15, 2022 at 9:35 AM
    NmapFE
    NmapFE Well-Known Member
    2014 DCLB 4x4 Limited. 6112’s/5125, KYB Top Hats, SPC UCA’s, Icon RXT leaf pack,
    Sorry I missed that … was moving too fast and didn’t pay attention
    Hook78[QUOTED][OP] likes this.
  3. May 15, 2022 at 9:39 AM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    Did you try bolting it on with vehicle on ground? Or you can jack up the rear axle if in the air. I've done it on countless 2nd and 3rd gens. Once bolted, bend into position.
    Hook78[QUOTED][OP] and NmapFE like this.
  4. May 15, 2022 at 9:53 AM
    NmapFE
    I made this mistake at first too , until I lowered it and then it worked like a champ once off the stands…
    Superdave1.0[QUOTED] likes this.
  5. May 15, 2022 at 9:54 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Yeah my attempts have been with the truck just sitting in the drive way. I would have to murder the guide to position it in a way that wouldn’t put major force on the brake line.
    Unless…are you bolting it on the bracket closest to the tire or the one furthest forward?
    Superdave1.0[QUOTED] and NmapFE like this.
  6. May 15, 2022 at 9:55 AM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I can see from this photo it’s the bracket closest to the tire. Ain’t gonna work on mine. I’ll take a photo when I get home.
  7. May 15, 2022 at 10:05 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers, a skewp and a bit of droop.
    I would bolt it up wherever you can. It just needs to support the line through the suspension cycle. I had mine zip tied to the leaf while I figured out to ream the hole to fit and give it a new bend.
    Subd for pics.
    Edited for pics:
  8. May 15, 2022 at 10:12 AM
    Jared8907
    Jared8907 txtaco07
    Texas
    2015 DCLB 4x4
    Weathertechs Tint Led Interior Method NV TRD Pro Bilstein Suspension Icon AAL CaliRaised sliders
    I drilled abs tapped the spring clamp, sits about where the stock line hanger was.
    SR-71A, Superdave1.0 and NmapFE like this.
  9. May 15, 2022 at 10:16 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  10. May 15, 2022 at 10:36 AM
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I bolted mine right up after reaming out the hole on the bracket a little. Super simple.
  11. May 15, 2022 at 10:42 AM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Some good ideas over here :thumbsup:
  12. May 15, 2022 at 10:50 AM
    Superdave1.0
    SoCal
    I've done this as well. More work, but it does sit lower which is nice.
    Jared8907[QUOTED] likes this.
  13. May 15, 2022 at 10:53 AM
    Superdave1.0
    SoCal
    So I'd assume you're having issues with the one that attaches to the frame. That one can be a bear to get back on if you removed it.
  14. May 15, 2022 at 1:14 PM
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    No that one is intact. Posting a picture below, you’ll see what I’m talking about.
  15. May 15, 2022 at 1:18 PM
    #35
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    Hopefully these photos help clarify. First one is where the bracket and brake line sit at ease. Second one shows the highest I can lift the bracket, relative to the bolt many of you have secured it to. Any higher and I’d be putting far too much pressure on the brake line. Really what I need is some kind of bracket that would hang down from that leaf bolt.
    2982FCAF-D139-4F80-8F2A-D72FC3D81153.jpg 1DCC3528-27F0-40C6-A47D-0A00CC485DB5.jpg
  16. May 15, 2022 at 2:01 PM
    #36
    AllTacosFloat
    Boston ish
    Put it where it goes and bend to where it needs to be. Telling you it really will work like the rest of ours but if you think you need a little bracket home dump will have everything you need.
    Superdave1.0 likes this.
  17. May 15, 2022 at 2:14 PM
    #37
    Superdave1.0
    SoCal
    It will work. I lift Tacomas every week. Is the E brake set when you are trying? Make sure the E brake is off.
    Edit: Also the easier way is to have the leaf spring bolt facing the other way. Then it leaves a stud for you to place the bracket onto.
  18. May 15, 2022 at 2:16 PM
    #38
    Hook78
    Eastern NC
    2015 DCSB TRD OR
    I looked at post #5 again and I think I was misunderstanding the way in which the bracket gets bent. Can you confirm that it gets bent out and down? If looking at the driver’s side bracket from the front of the truck it would rotate 90 degrees clockwise. Yes?
  19. May 15, 2022 at 2:18 PM
    #39
    Superdave1.0
    SoCal
    2nd option is to buy a tap. Drill and tap a hole a couple inches under the gold bolt there on your leaf spring bracket. Bolt the bracket to your new hole.
  20. May 15, 2022 at 2:19 PM
    #40
    Superdave1.0
    SoCal
    Honestly you should flip this bolt around regardless. Some have had their fuel tanks nearly punctured from that bolt facing the way you have it.
    CemenTRDgen and Hook78[OP] like this.
