Replacement brakes, rotors, shocks
Discussion in '1st Gen. Tacomas (1995-2004)' started by Braindead, Jul 24, 2015.
  1. Jul 24, 2015 at 6:44 AM
    Braindead
    Braindead [OP] Well-Known Member
    JoJo
    Atlanta
    02 PreRunner
    I need advice! My 2002 V6 Prerunner has 140,000 miles on it and still has original EVERYTHING.
    I am rebuilding it one piece at a time. My next project is to replace front/rear brakes and shocks.
    This is a street truck but occasionally I will pull a light camper.
    Who has the best quality?
    I also need to find a good mechanic who has lots of experience with Tacomas. I live in the Atlanta, GA area.
  2. Jul 24, 2015 at 6:55 AM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    bilstein 4600 series HD shocks and genuine OEM Toyota rotors and pads,just so happens I have the Bilstein part# Im replacing mine with the HDs got 179k miles on my present set and are still going>2 fronts #B46-2284 HD and rears B46-2285 HD and B46-2286 HD (there are 2 different part #s one for left,one right rear)best price Ive seen was EBAY for all 4.
  3. Jul 24, 2015 at 6:57 AM
    Mush Mouse
    mush
    2013 SR5
  4. Jul 24, 2015 at 7:04 AM
    Mush Mouse
    mush
    2013 SR5
    you can do the rear shocks yourself and save $$$,but the fronts the coil has to be compressed and maybe a new front end alignment. get the oem brakes and rotors, just had my rear brakes replaced at over 200k miles so yours probably are still good just need to be cleaned out with brake cleaner and deglaze the inside drums with emery cloth and new brake fluid(bleed or flush)
  5. Jul 24, 2015 at 7:53 AM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    If you can remove bolts, you can do the shocks. If you can remove bolts, you can do the front rotors and pads. The drums are a bit different, I have never worked on drums before, but I found them to be pretty easy. The tricky part for me were the adjusters. If you decide to do them, we can help you here. Save the $ and start learning about your truck. It can be fun, and it is rewarding doing it yourself. If it is out of your comfort zone, there are times when I feel it better to involve a shop, by all means find a good one and go there.
    OEM rotors, drums, shoes and pads. I figured with my rears that they lasted 140k mi...why not.
    Good luck! Oh and buy a Haynes or a Chiltons, they are a very good resource.
  6. Jul 24, 2015 at 7:54 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    Mush,
    That saves me a lot of legwork! The previous owner of my truck was a rock climber and ignored the truck's maintenance. Rear drums and front rotors are shot. Driving this truck is a real challenge.
    Thanks,
    JoJo
  7. Jul 24, 2015 at 8:01 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    Jim,
    I am going to have a go at it. Retirement necessitates DIY. I wish I could find a Taco buddy in Atlanta to hold my hand. I have two vehicles so I can take my time.
    JoJo
  8. Jul 24, 2015 at 8:36 AM
    Mush Mouse
    mush
    2013 SR5
    if u do the rear shocks yourself its a little more room to work if you remove the spare tire, I think the bolts are 17mm? and also when u put on the new ones(rear)the new shocks come compressed with a band holding them compressed,put the upper bolt of the shock on and thread the bolt down to hold it down then cut that band with a knife let it open until you can throw on the bottom bolt it down or else you will have to test out your bench pressing strength to compress it on. and use the new washers in the shock kit comes with
  9. Jul 24, 2015 at 8:39 AM
    Mush Mouse
    mush
    2013 SR5
    buy the Toyota OEM parts online and have a shop put them on or just have the stealership that has the parts do it sometimes they have discount service coupons I used one for my rear brakes at the stealer works out cause I will never need a new set of rear brakes again and all Toyota OEM parts
  10. Jul 24, 2015 at 8:43 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    Thanks, glad you told me about cutting the band!
  11. Jul 24, 2015 at 8:43 AM
    Mush Mouse
    mush
    2013 SR5
    heads up if you do it yourself^
  12. Jul 24, 2015 at 8:44 AM
    scocar
    scocar Patron of the Farts
    If you want stock rotors, I replaced with Centrics at 135k miles.
    Rotor PN 105.04360
    Pads PN 121.44109
    Working great, no issues or noise.
  13. Jul 24, 2015 at 8:54 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    Why do you assume I still have a working head?
  14. Jul 24, 2015 at 8:55 AM
    Braindead
    JoJo
    Atlanta
    02 PreRunner
    How about the drilled and slotted (expensive) rotors? I want the best!
  15. Jul 24, 2015 at 8:59 AM
    Mush Mouse
    mush
    2013 SR5
  16. Jul 24, 2015 at 9:00 AM
    Mush Mouse
    mush
    2013 SR5
    Toyota OEM best[​IMG]
  17. Jul 24, 2015 at 9:05 AM
    Bennett707
    Bennett707 Station707
    Oregon
    No more taco life for me
    upgrade to tundra brakes.
  18. Jul 24, 2015 at 9:06 AM
    scocar
    Not sure what that means. Knock yourself out.
  19. Jul 24, 2015 at 9:09 AM
    JJ04TACO
    Jim
    Dallas
    04 White DC/TRD
    Agree with the OEM statement. But I would look to the aftermarket for shocks. Front shock replacement? I bought assembled coil overs from Toytec, I won't mess with springs myself. Too dangerous for me.
    Go here to compare pricing. They serve me very well here in Dallas.
    http://parts.toyotaofdallas.com
  20. Jul 24, 2015 at 9:17 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    You can do the front brakes and pads yourself and the rear shocks. The front coilovers will require a spring compressor and alignment afterwards. The rear drum might also be a challenge. I like Brembo blank rotors as a OEM replacement myself.
