Replacement Clutch Recommendations
Discussion in '1st Gen. Tacomas (1995-2004)' started by Petrol, Nov 30, 2014.
  1. Mar 30, 2015 at 12:58 PM
    mytoy04
    mytoy04 Well-Known Member
    Tim
    Liberty, MO
    99 4Runner 4cyl 5sp 4x4
    Hey Petrol, did you do your clutch by now I assume? Curious what you went with and did you figure out your question in the original post about the RMS? I have a 99 4Runner starting to slip in 4th gear on heavy acceleration like up a hill and have been searching on what clutch to get. I too was thinking of the Aisin from rock auto.
    Did you happen to do this yourself? I'm wanting to try and do mine and curious how it went for you. My 4Runner is a 4cyl 4x4 I'm guessing they are the same as the Tacoma.
  2. Mar 30, 2015 at 4:16 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    I installed the Aisin kit from rockauto in my truck a little over a year ago and i love it. I tow a 2200lb camper and the clutch is performing great. I was planning on purchasing the Marlin Crawler kit but it was out of stock with no eta at the time, but i am happy with the Aisin kit.
  3. Mar 30, 2015 at 5:25 PM
    mytoy04
    Tim
    Liberty, MO
    Hey thanks 68dave. Have you done this job before? And did you replace the rear main seal too?
  4. Mar 30, 2015 at 5:33 PM
    68dave
    Dave
    Yea i've done a bunch of clutches and it's cheap insurance to replace the rear main seal while its apart. I have full use of a auto repair shop after hours with lifts so that makes jobs a lot easier.
  5. Mar 30, 2015 at 5:41 PM
    mytoy04
    Tim
    Liberty, MO
    Oh wow that would be nice. So what's the best way to get that pilot bearing out? In your opinion.
  6. Mar 31, 2015 at 4:17 PM
    Petrol
    Petrol [OP] Well-Known Member
    Central Va.
    Tacoma
    I adjusted the clutch and it's working fine for now. Going to try to get a few more miles out of it.
  7. Mar 31, 2015 at 6:57 PM
    68dave
    Dave
    I use a pilot bearing removal tool.
  8. Apr 1, 2015 at 5:34 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    I borrowed a blind hole puller from Autozone. It took longer to get the tool out and put it away than it did to pull the bearing.
