replacement cv boots
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stanman9, Jul 21, 2009.
  1. Jul 21, 2009 at 3:22 AM
    stanman9
    stanman9 [OP] Well-Known Member
    Toytec co's and aal, tc uca's
    I tore my Right side inner and outer boots. How hard are these to replace and what kind should I replace them with???
  2. Jul 21, 2009 at 4:22 AM
    JetTech
    JetTech Member
    East Bay, NorCal
    07 TRD Sport D-Cab Long Bed 4X4
    Icon/5100, N-FAB Side steps, AIRAID Intake, Secondary air filter removed, WeatherTech's, OEM roof rack, USA-spec ipod adapter, A/C-defrost mod,2ea Delta bike Hitch Pro2 Locking bike mounts,TRD Skid,Polk 6x9/6,RedLine hood struts,under-hood led lighting...
    Free bump for you... and my own curiosity:popcorn:
  3. Jul 21, 2009 at 8:06 AM
    DDD
    DDD Shine bright like a hymen
    Derek
    Santa Clarita, CA
    I think it is easier to replace the front axle.
    I don't think you can stretch a new boot over the axle. Therefore, you would have to take apart the CV.
  4. Jul 21, 2009 at 8:13 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
  5. Jul 21, 2009 at 8:20 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Buy the CV boot kit from Toyota. Comes with new boots, clamps, grease, etc.
    Replacement is easy but a freaking mess.
    . To remove the axle, unbolt the 35mm axle nut and the spindle.
    . Dead-blow hammer helps knock the axle out of the spindle at this point.
    . Use a pry-bar to pop the axle out of the front differential. Drain the front differential fluid first and make sure you refill when you're done reinstalling everything.
    . Cut the boot on the inner CV joint and pull all that stuff apart
    . Remove the C-clip holding the tripod in place at the inner end of the axle and use a pulley puller to remove the tripod from the axle.
    . The outer CV boot can now be removed either by cutting or by sliding it down the axle and off the inner end.
    . Tape the threads on the inner end of the axle so you don't damage the new boots when you slide them on.
    . Grease up the outer CV and slide the new boot onto the axle from the inner end. .Tighten up the clamps once everything is in place and you've bumped any air from inside the boot.
    . Slide the inner boot onto the axle.
    . Remove the tape and reinstall the tripod.
    . Install the new c-clip supplied in the Toyota kit.
    . Grease stuff up and reinsert the tripod into the inner CV cup.
    . Burp the inner boot and tighten up the clamps.
    . Slide the axle into the differential. I used a pry bar on the ridges of the inner CV cup and a dead-blow hammer to knock the axle back into the diff. It'll seat itself when it's in far enough.
    . Reassemble the spindle end of things.
    . Change your clothes. You're covered in grease.
    It should only take you about 2 hours per side during your learning curve. Probably an hour once you have the process down and all the tools handy.
  6. Nov 20, 2009 at 9:53 AM
    Sapper26
    Sapper26 Well-Known Member
    Will
    Columbus, GA
    99 Xtra Cab 4x4
    So here is a little update. I just finished pulling out the driver side front axle on my 2010 double cab and have a few comments to make about the process. First, you don't need to remove the brakes and wheel hub assembly to get the axle out. Once you pull the lower ball joint and steering there is more than enough room to pull the axle. You may have to tap on the end of the axle with a hammer to get it free, just be careful not to damage the splines.
    Next, to get the axle out of the front diff. you do not need a slide hammer. You can turn the axle and use a long pry bar to pop out the axle.
  7. Nov 20, 2009 at 9:57 AM
    mjp2
    NJ
    Yup.
  8. Nov 12, 2010 at 10:49 AM
    4cyltacoma
    4cyltacoma Well-Known Member
    Reagan
    Fresno, Ca
    06 Tacoma SR5 4Cyl 4x4
    AFE CAI, Black Housed Headlights, In Channel Window Visor, Bug Deflector, Black Side Step Tubes, Blacked out emblems
    Any pictures for the work u did??
  9. Nov 12, 2010 at 11:05 AM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
  10. Nov 12, 2010 at 4:36 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    I haven't done the in many years but I seem to remember a split CV boot that you could just put on with some radiator hose clamps and sealant No need to remove axle. Got it at the local auto parts store.
  11. Nov 12, 2010 at 4:40 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Those are a waste of money. You'll end up making a mess and ruining the axle. They work ok if you need it in a pinch. But for a permanent fix do it right.
    I've seen guys use them on honda's and acura's and within 3 months are replacing them again. Keep in mind those cars don't have nearly as much cv angle as our trucks do.
  12. Nov 12, 2010 at 4:46 PM
    george3
    New Jersey
    I'm sure you are right. Like I said it's been years and I don't even remember how it lasted only that it was a easy quick solution.
  13. May 3, 2011 at 7:25 PM
    tictoc
    tictoc Active Member
    HAWAII
    FABTECH
    fabtech 6 in,33 procomp x terrain/micky thompson 17" beadlocks,steering stabilizer kit,k&n 77 series intake with throttle body spacer,ravin exauhst
    hey guys im changing mine and i have a few questions if i may........in the kit from toyota i have 4 pouches of grease two brownish colored 1 big 1 small and 2 blacks big n small??? question is wut goes where?? and my other question is is it a must so get new oil seals?
  14. May 4, 2011 at 2:47 PM
    mjp2
    NJ
    I wouldn't mix 'em.
    I imagine you'll figure out which grease goes where when you pull apart your axles based on what you find in the existing boots. I'd hope Toyota used the same grease at the factory as they provide through the dealerships.
    basoccer8 likes this.
  15. Sep 19, 2012 at 2:51 AM
    holyfield19
    holyfield19 GO TIGERS!
    Bob
    South Carolina
    06 DC TRD Sport 4X4
    Busted CV boots and lots of squeaks.
    subarooski
  16. Mar 18, 2014 at 7:32 AM
    j83soldier
    j83soldier Well-Known Member
    joshua
    Colorado
    05 tacoma
    anti lock brake disable mod, fogtime anytime mod, Leer Topper, all pro plate bumper, toytec 3 inch lift, bfg AT, rims, piaa 5100's, some double din head unit (cant remember), warn 8000 winch, DO sliders, hacked frame to fit full size spare, thule and yakima roof racks
  17. Mar 27, 2014 at 4:03 PM
    -TRDMAN-
    -TRDMAN- ΜΟΛΩΝ ΛΑΒΕ
    Greg
    Clarion Pa
    F-150
    Anybody know if I will need to add and or replace diff. Fluid after replacing the axle?? Thanks!
  18. Apr 26, 2014 at 7:15 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    2010 Dbl Cab 5' Box 6 Speed
    2010 Tacoma, sold...
  19. Apr 27, 2014 at 12:35 AM
    george3
    New Jersey
    Great find:D - I usually search Youtube. Do you find a lot of good stuff on Vimeo ? I searched it for Tacoma brakes just 2 C what would come up - nothing. Thanks.
  20. Apr 27, 2014 at 8:50 PM
    Foihdzas
    Foihdzas VA7PTZ
    Danny
    B.C Canada
    I just replaced my first cv boot today. A bit of a learning experience, but thanks to that video, it was easier than expected.
