Replacement Front Eye Dakar Bushings
Discussion in '1st Gen. Tacomas (1995-2004)' started by License2Ill, Aug 16, 2014.
  1. Aug 16, 2014 at 10:10 AM
    License2Ill
    License2Ill [OP] Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Hi all. I was installing a new AAL in my Dakar pack the other day and noticed the front eye bushing was toast. It seems that the inner sleeve that surrounds the mounting bolt became separated from the bushing and ate away at it. It seemed to only eat downward, until it hit the outer sleeve. Leaving just an elongated oval, the rest of bushing seemed in good condition. :confused:
    Anyway, I remember reading the Dakar's use the OEM rubber bushing. Can anyone confirm? Has anyone used poly in this application?
    Has anyone ordered these? Or has anyone tackled this job?
    Mucho Por Favor.
  2. Aug 17, 2014 at 11:13 AM
    License2Ill
    Ian
  3. Aug 18, 2014 at 8:51 AM
    License2Ill
    Ian
  4. Aug 18, 2014 at 10:47 AM
    2scars
    2scars Swollen Member
    Brandon
    RVA
    2003 TRD 4x4 Doublecab
    All-pro, T-G, Budbuilt, Warn, Tepui, Homefab rear bumper
    Boxrocket swapped his with Factory OEM bushings I believe, may be will chime in.
  5. Aug 18, 2014 at 6:17 PM
    License2Ill
    Ian
    Okay. Thanks for that info.
    I called wheeler's this morning and they confirmed Dakar's use stock 60mm bushings in the front eye of the leaf. Stock tacoma leaves use 60mm for both front and rear eyes.
    I got the poly ones I listed in the OP because I don't have convenient access to a 20 ton press. I'd rather not pull my whole leaf pack out again to press them in. And since that kit has 4 of the same size bushings, if the first ones take a shit quick I'll have a pair of spares to throw in there. At $6.50 per leaf eye, it's hard to beat.
  6. Mar 22, 2017 at 9:24 PM
    ETAV8R
    ETAV8R Out DERP'n
    MGM 09 AC 4WD V6 TRD-OR w/ Tradesman Shell
    Just the basics
    Found this thread while searching for bushings on the leaf packs. What did you end up doing? All my bushings are crapped out.
  7. Mar 23, 2017 at 12:04 PM
    License2Ill
    Ian
    I went with these: They're stock 1St gen front leaf bushings. But they fit the front Dakar application. Not sure for second gen though....
    It involves drilling out the old rubber bushing and REMOVING the old outer sleeve.
  8. Mar 23, 2017 at 12:05 PM
    License2Ill
    Ian
    And I use the yellow OME for the rears.
