Replacement headlamp recommendations?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12Tac, Dec 17, 2016.
  1. Dec 17, 2016 at 12:37 PM
    12Tac
    12Tac [OP] Well-Known Member
    Colorado
    2020 Double Cab, Long-bed TRD Off Road.
    SnugTop, FN Wheels, Meso Custom, Tacos4Cheap
    Hey All,
    I was replacing my headlight bulbs this afternoon, got the driver side done no problem. The passenger side rubber socket cover was pushed as far down on the bulb as possible (factory installed) so I ended up pulling the entire bulb and cover out in one piece. Well that snapped off the plastic element that holds that metal spring tension that holds the bulb into the assembly. It looks like I'll need to replace the entire headlamp assembly.
    So where is the best place to get OEM, perfect fit replacements?
    Thanks,
    12Tac
  2. Dec 17, 2016 at 6:06 PM
    Pigpen
    Dan
    Northwest Montana
    They show up in the 2nd gen marketplace fairly often. I sold mine when I bought the Pro headlights. Or you could pony up and buy the Pros. I forget if I went with Camelback Toyota or Toyota Partznet for mine.
  3. Dec 18, 2016 at 4:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
  4. Dec 18, 2016 at 4:26 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    You can get pro headlights for 400 shipped in the deals section. Look for the duke of deals round 2.
    crashnburn80 likes this.
