Replacement headlights
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ARO5384, Jan 28, 2018.
  1. Jan 28, 2018 at 5:21 PM
    ARO5384
    ARO5384 [OP] New Member
    2008 Silver Tacoma TRD Manual
    Hey- Am looking to replace my headlights on my 2008- Where is a decent source for this, with a quality product that will last? My stock headlights have faded, and one side has developed a crack-
    Thanks for your input!
  2. Jan 28, 2018 at 5:26 PM
    myth01
    myth01 Well-Known Member
    south sf, ca.
    08 taco Trd sport
    eclipse nav.-w/ Bluetooth & iPod 3'' revtech add a leaf lift kit snug top ss truck cap dive tank racks in back Aux fuse box Aux back up lights, w/ interior fj cruiser stock switch Back up cam Turn signal cams Interior inverter -switched Aux audio/video inputs -RCA (including iPhone cable)w/ 4 input switch Mag light mount Tyredog stand alone tpms Spare tire extension hose Avid off road light bar(powder coated)
  3. Jan 28, 2018 at 7:13 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Oem.
    Get the housings alone... theres diff part numbers for just the housings..
    Then another number for housings with bulbs, spring keepers, and boots. This stuff is extra $$ and can be swapped over from ur stock setup.
  4. Jan 28, 2018 at 9:22 PM
    myth01
    south sf, ca.
    08 taco Trd sport
    So there is really no good after markets?
  5. Jan 28, 2018 at 9:23 PM
    inwood customs
    Dave
    Find CAPA certified varients maybe...
    Others will chime in.
    Most aftermarket crap has worse optics, and they leak.
  6. Jan 28, 2018 at 9:25 PM
    inwood customs
    Dave
    Most important.... AIM the new lights.
    They will not be aimed out of the box... ive seen ppl surprised at this.
    crashnburn80 likes this.
  7. Jan 28, 2018 at 9:32 PM
    Hairy Taco
    Hairy Taco Jungle of Love
    North of Hell
    08 TRD
    I replaced my stock headlights a few years ago with an aftermarket headlight called Depo. They have been fine, but I did lay a bead of permatex to reinforce the factory seal. I don’t think the output is a good as the OEM were.
    inwood customs likes this.
  8. Jan 29, 2018 at 1:04 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Welcome to TW!
    Under section 3) in this thread, there are links to buy the unloaded housings as mentioned above, but in smoked chrome (you can find cheaper in shiny chrome):
    https://www.tacomaworld.com/threads/the-ultimate-headlight-upgrade-h4-not-led-or-hid.398066/
    No aftermarket headlight is going to beat the OEM assembly. They will be a reduction in performance and quality. If OEM is out of the question, the next best option is to go for CAPA certified lights. I would not recommend non-CAPA assemblies.
    When installing, do one at a time. After installing the first one, point your truck at a wall 20-25ft away, and adjust your new beam to meet your old stock beam cut off. When you swap the 2nd new one in, repeat the adjustment to match your first. That way your headlights are adjusted to the stock position.
  9. Jan 29, 2018 at 1:41 AM
    runner05
    runner05 Well-Known Member
    Karl
    You might want to consider aftermarket ones like Spyders and Spec-D.
  10. Jan 29, 2018 at 1:48 AM
    inwood customs
    Dave
    Those have a terrible track record as we have see over the years.
  11. Jan 29, 2018 at 2:26 AM
    06Tacooo
    06Tacooo Earth Czar
    Mark
    39° 14' N / 83° 13' W
    06 Off Road Access Cab Indigo Ink Pearl
    Michelin Defender LTX M/S2, ABS kill switch, Tech Deck, Mirror riser, Ride-Rites, BF Garmin GPS
    Stick with the correctly engineered DOT certified headlamp assembly for your specific truck. That way you won't have any of the problems associated with aftermarkets. 10 years lifespan isn't bad at all. My 06 still has originals, and upgraded Halogen lamps. https://store.candlepower.com/64205.html
  12. Jan 29, 2018 at 3:14 AM
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    That’s a great idea....wish I had done that
    OP - OEM is the way to go. A little pricey but worth it...
