Replacement Interval for 2.4L O2 and AF Sensors?
Discussion in '1st Gen. Tacomas (1995-2004)' started by joshhemming, Oct 18, 2015.
  1. Oct 18, 2015 at 8:17 AM
    joshhemming
    joshhemming [OP] Active Member
    Josh
    El Paso
    03 Tacoma SR5 2.4L Extended Cab
    I have the 2003 2.4L Tacoma with 73,000 miles.
    Are the Oxygen and Air to Fuel Sensors supposed to be replaced at any particular interval, or do you just wait for a Check Engine code to alert you that one has failed?
  2. Oct 18, 2015 at 8:21 AM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    Just wait. MAFs have lasted for a long time with no consumables in them. O2 sensors do need to be replaced. Most wait for the MIL since they are not cheap.
  3. Oct 18, 2015 at 8:28 AM
    joshhemming
    Josh
    El Paso
    I'm not talking about the MAF....by AF I'm referring to what some people call the "upstream" O2 Sensor. As I understand it, there's an upstream O2 sensor (actually an Air to Fuel sensor) BEFORE the catalytic converter and an actual O2 sensor AFTER the converter. Just wondering if these two sensors should be replaced at a certain interval.
    I think you're right about the MAF not needing regular replacement, though. I have a feeling those are VERY expensive.
