Replacement Interval for Transfer Case Fluid, Transmission Fluid ect. Official Documentation?
Discussion in 'Canada' started by Tunngavik, Aug 6, 2022.
  1. Aug 6, 2022 at 8:04 PM
    Tunngavik
    Tunngavik [OP] Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    I'm looking for official Toyota documentation on the required intervals to change other fluids in the truck (i.e. not engine oil, brake fluid and coolant).
    The Canadian owners manual provides clear information on when to change the engine oil and coolant. The Toyota Canada website (https://www.toyota.ca/toyota/en/owners/maintenance-schedule) provides information on when to change the brake fluid (every 36 months FYI)
    The Toyota USA site has a maintenance guide but only provides the following guidance under "special operating conditions"
    Additional Maintenance Items for Special Operating Conditions
    Driving on dirt roads or dusty roads:
    Replace transfer case oil (4WD)
    Driving while towing, using a car-top carrier, or heavy vehicle loading:
    Replace front differential oil (4WD)
    Replace manual transmission oil
    Replace rear differential oil
    Perform these service items only if you drive primarily under the conditions indicated.
    I don't tow, load the vehicle excessively (the heaviest things I haul is a dirt bike or camping equipment), use a roof top carrier nor do I drive on dirt roads much (maybe 5%). I doubt if that means that I never have to change these fluids.
    My wife's Volvo has all this information in her maintenance guides. Does anyone have any official documentation from Toyota when you have to change these fluids (aside from what I listed above) or point me in the right direction?
    Kodiak420 and bigmw like this.
