Replacement key for 2015
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NE4now, Apr 28, 2017.
  1. Apr 28, 2017 at 12:24 PM
    NE4now
    NE4now [OP] Active Member
    Central MA
    I need a new key for my 2015 Tacoma (it only came w/ 1) and the dealer quoted me $130+ for just the spare. I dont even need a remote because I had a viper remote starter installed and that fob replaces the factory ones.
    Can this key just be ordered based on VIN?
  2. Mar 28, 2018 at 7:34 AM
    zakattak
    zakattak Well-Known Member
    Zak
    California, MD
    2015 TRD Sport DCLB
    In the same boat... Need a replacement key for a 2015. Not the fob just the key
  3. Mar 28, 2018 at 7:40 AM
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    If you have the 4 cylinder I cannot say for sure because I don’t know if any of them have it, but I am pretty certain all v6 motors came with immobilizers which means your key has a chip in it. If you get a normal $10 key and have them cut it, it will open doors but not start the truck. If you post a picture of your key, or look for a marking on it, right before the thicker part of the key. Some have a dot, some have a G, and I am sure there is other engravings too that tell you if it has a chip in the key or not.
  4. Mar 28, 2018 at 7:41 AM
    zakattak
    Zak
    California, MD
    2015 TRD Sport DCLB
    Yes I have the "G" on my key.
    So what do I get? Just want a spare key or two... And get them reprogrammed together with the one I have?
  5. Mar 28, 2018 at 8:04 AM
    Murphinator
    Anthony
    SoCal
    14 DCSB 4x4
    So I don’t have an exact part number but the key you have does have the chip inside it. So for them to start the truck you will need to get another key with the G engravings. You should be able to call a toyota dealer and give them your vin and they will be able to tell you the part number. I have heard some lock smiths can program/cut the keys so you may want to call some and see what they say.
  6. Mar 28, 2018 at 8:07 AM
    zakattak
    Zak
    California, MD
    2015 TRD Sport DCLB
    I found "OEM 2012-2015 Tacoma G key" on eBay. $13 a piece. Needs to be cut and programmed. Reviews said the same. Has a p/n of...
  7. Mar 28, 2018 at 8:08 AM
    zakattak
    Zak
    California, MD
    2015 TRD Sport DCLB
  8. Mar 28, 2018 at 8:15 AM
    odomandr
    odomandr Well-Known Member
    Andy
    Fort Collins, CO
    2010 DCSBTRDOR silver streak mica 2023 T4R Ltd blizzard pearl
    Icon, SPC,, ARB, BAMF, Warfab, SCS, Michelin, Leer Stock
    buy them online, get ACE to cut them, then reprogram with the tool off Amazon.
  9. Mar 28, 2018 at 8:17 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    If you go to Walmart,try, they do chipped keys for $40
    REDdawn6 likes this.
  10. Mar 28, 2018 at 8:27 AM
    atompson
    atompson Well-Known Member
    Andrew
    Dallas, TX
    Tompson
    None.
    Anyone in the North Texas area, I have a programmer that I bought for the chipped keys. Glad to let you borrow it for a six pack.
    ElChingon likes this.
  11. Mar 28, 2018 at 8:37 AM
    Alder932
    Alder932 Well-Known Member
    B.C., Canada
    2013 Tacoma Limited
    I don't need to program any keys (and being in Canada it would be a long trip), but the response from member atompson showcases one of the reasons that I have come to really appreciate the Tacoma World community. Classy.
  12. Mar 28, 2018 at 9:02 AM
    fast5speed
    fast5speed Well-Known Member
    Washington D.C.
    2005 Access Cab 5speed 4cyl 4x4 SR5
    Would you mind sharing which one(s) you're speaking of? Providing a link perhaps?
  13. Mar 28, 2018 at 9:08 AM
    atompson
    Andrew
    Dallas, TX
    Tompson
    None.
  14. Mar 29, 2018 at 8:32 AM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    A 2015 V6 should be a "G" key. Not all places can program those. My local dealer wanted $200 for the key & programming. I found a local locksmith and paid $40 for the key and $50 for programming. I had my key made just over a year ago.
    kimo likes this.
  15. Mar 29, 2018 at 8:42 AM
    kimo
    kimo Well-Known Member
    Knuckle Head
    Kauai
    09 Super White TRD Sport DCLB 4X4! 2017 Silver 4Runner!
    Another solution. Tape your chipped under the dash somewhere hidden and get a couple regular keys cut. They will work to start your vehicle if the chipped key is within a few feet of the ignition....so I am told?
  16. Mar 29, 2018 at 8:54 AM
    kimo
    Knuckle Head
    Kauai
  17. Mar 29, 2018 at 8:57 AM
    kimo
    Knuckle Head
    Kauai
  18. Mar 29, 2018 at 9:26 AM
    PzTank
    PzTank Stuck in the Well
    Above the Notches
    ‘15 AC SR5 4X4 4.0 Auto
    ‘07 OR leather shift knob
  19. Mar 29, 2018 at 1:21 PM
    atompson
    Andrew
    Dallas, TX
    Tompson
    None.
    I didn't know about this when I bought the programmer. I don't know if this works in Tacoma or not. I'd be curious.
  20. Mar 29, 2018 at 1:26 PM
    Troyken
    Troyken Well-Known Member
    NY
    2013 DCSB v6 off road 4x4 6 spd. MT
    I just went to Home Depot for this issue. They have a scanner that claims to verify if your key is a transponder key. Mine could not be verified as such. The lady scanned the key and cut it on a plain blank. It opened the door lock and CRANKED the truck but no start. I tried holding my factory key on the steering column near the key switch but no luck in starting.
