Replacement knuckles for 1st gen taco.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Levisbustedtacoma, Dec 4, 2022.
  1. Dec 4, 2022 at 4:30 PM
    shankyjones
    shankyjones Well-Known Member
    Richard
    Marina CA
    2003 Brown Tacoma Prerunner V6 3.4L TRD
    Just take your time. Making sure the drill bit is square before drilling. They are too difficult
  2. Dec 4, 2022 at 4:33 PM
    shankyjones
    Richard
    Marina CA
    Aren't, that is
  3. Dec 4, 2022 at 4:36 PM
    Levisbustedtacoma
    Levisbustedtacoma [OP] Well-Known Member
    Levi
    01 4x4 extracab
    Bilstien 5100s eibach coils Dakar leafs Chinese balljoints
    10-4. I did button it all back up to move the truck so I can get my 87 yota out to get to work. It'll have to hold till this coming weekend. Hopefully I'll have decent weather at least. And yes the truck rolled around the yard to another spot without issue. I had to cut the stupid swaybar link to replace the cv and that piece of crap is not going back on.
  4. Dec 4, 2022 at 10:37 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Take the time to read the link is post #2, very good information about what torque value for lower ball joint bolts. It all depends on which bolts you have.
    Area51Runner likes this.
  5. Dec 5, 2022 at 8:42 AM
    Chungas
    Chungas Help! My Ferret has lost its stank!
    Waylon
    Bushwood CC
    Cocain 2003 3.4 4x4
    I don't know if Toyota changed the spec on the black bolts with washer but from experience, 59ftlbs for these bolts is too much.
    OP, you should be able to get the sheared bolts out without too much trouble. The blind holes on the outer side of the spindle can be a pain but stubbornness usually wins.
  6. Dec 5, 2022 at 8:45 AM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
    Apparently the bolts with washers are a lighter spec. I was using Chinese bolts that came with the balljoint. It was obvious the originals that I reused originally when I did the balljoints were stretched this time around doing the cv
  7. Dec 5, 2022 at 9:19 AM
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    Take the helicoils and throw in the trash before you begin. Those will come right out w/ left handed drillbit. I don't see anti seize on them bolts either. If I was there I would rub some in your hair for not using it.
    Bivouac and Area51Runner like this.
  8. Dec 5, 2022 at 9:52 AM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
    I felt that way about helicoils. Anti seize on a bolt that many call for locktight on? You don't see the lock tight on the bolt?
  9. Dec 5, 2022 at 9:53 AM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
  10. Dec 5, 2022 at 11:15 AM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    OP doesn't appear to be running the dust protectors so if it were me I'd be using 8 new ARP bolts and torque to 59 ft lbs.
    If he were running the dust protectors, the only bolt to use with them is the black w/washer and torque to 37. No more, no less. 37 ft lbs.
    As for threadlocker, I wouldn't use any on the LBJs but that's just me. Also trusting helicoils and LBJ bolts? Hell no. I'm not that lucky.
    15psd likes this.
  11. Dec 5, 2022 at 12:56 PM
    shankyjones
    Richard
    Marina CA
    Interesting that 2 people say not to use the helicoils for lbjs. How else would a person rethread those knuckle holes?
  12. Dec 5, 2022 at 1:40 PM
    Levisbustedtacoma
    Levi
    01 4x4 extracab
    Quality hardware is Def on the list, however, the size may be different if I have to retain. Scared of helicoils in this spot especially
  13. Dec 5, 2022 at 2:51 PM
    shankyjones
    Richard
    Marina CA
    I am interested in hearing what area51 says. I need to do one of mine as well. Thinking about drilling a slightly larger hole in both LBJ and knuckle and using a slightly larger bolt. Tapping the knuckle hole of course and going really slow as it is cast iron
  14. Dec 5, 2022 at 2:55 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I put Never Seize on all my Bolts
    I only torque Engine Internals and Bolts over 100 Foot Pounds
  15. Dec 5, 2022 at 2:56 PM
    #35
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    no cast iron on the knuckle. Forged steel.
  16. Dec 5, 2022 at 2:58 PM
    #36
    shankyjones
    Richard
    Marina CA
    I thought it was cast iron. My bad. Why does forged steel strip so easily?
  17. Dec 5, 2022 at 2:59 PM
    #37
    Area51Runner
    So my take on the LBJs/knuckles - I'm in CA and rust isn't an issue with those bolts, I would never toss antiseize on them. I also wouldn't tap it simply because in my mind its a critical safety item. I'm financially cool with replacing the entire knuckle if the threads were fragged. In the end, it's what you can live with bud. Everyone has to make their own call.
    It's like the dust protector. Most could care less it seems. Some do. Choices... :evil:
    Cheers.
    theesotericone and Bivouac like this.
  18. Dec 5, 2022 at 3:03 PM
    #38
    shankyjones
    Richard
    Marina CA
    Area51 - that is sound advice. Anyone have a spare set of knuckles in decent shape??
    I'm not financially cool as I used to be so gotta try and save a few (lots) bucks
  19. Dec 5, 2022 at 3:11 PM
    #39
    Bivouac
    Here everything rusts even new steel in the Rack if not treated
    It comes down to location !
    It is always a personal choice .
    I come up with interesting ways to fix my things.
    Area51Runner[QUOTED] likes this.
  20. Dec 5, 2022 at 3:11 PM
    #40
    Area51Runner
    drr likes this.
