Replacement of HVAC Blower Motor Resistor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garyods, Apr 26, 2008.
  1. Jan 12, 2022 at 6:34 PM
    #181
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    You’ll know immediately when you pull the connector.
    tacoman45[QUOTED] likes this.
  2. Jan 12, 2022 at 7:45 PM
    #182
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Resistor or connector going to it.
    tacoman45 likes this.
  3. Jan 14, 2022 at 8:46 AM
    #183
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    So I found this thread to see where the resistor is to test mine (mine also seems abnormally low on the two lowest settings - unless this is another Taco feature I didn't know about) and from the looks of the pics, the body extends into the duct? Is there some kind of sensor in the pact where it has to monitor the stream?
    I found this article about the problems with the resistor, but it doesn't mention any kind of sensor.
    https://www.fixmyoldride.com/Toyota-Tacoma-blower-problems.html
    Looking at images on Rock Auto, it looks like there is a solder blob that is exposed on one side. Is that a sensor? If it is a sensor, what is it monitoring?
    If there is no sensor, why mount it in the duct? Like can I pull it, block the hole, and clip the sensor somewhere so it will be easier to change on any future swap?
  4. Jan 14, 2022 at 9:15 AM
    #184
    tacoman45
    tacoman45 Well-Known Member
    Orygun
    2014 TRD OR DCSB - MGM
    2015WhiteOR likes this.
  5. Jan 14, 2022 at 9:25 AM
    #185
    bagleboy
    Scott
    Norcal, Santa Rosa
    It’s a resistor not a sensor and it’s there to be cooled by the airflow. It has several different resistance levels, hence the multiple terminals. Afik, when the resistor or connector go bad you ONLY have off/high, the other settings simply don’t work. Reduced output on lower settings might be an issue with the blend door actuator. Check to see if air comes out only where it’s supposed to on each vent setting(floor, dash, defrost).
    tak1313[QUOTED] likes this.
  6. Jan 14, 2022 at 11:46 AM
    #186
    tacoman45
    Orygun
    Good advice, although I will add that my connector crapped out leaving me with only 2/4 settings. Low & mid-low didn't work, mid-hi & hi worked just fine. Swapping in the kit fixed the problem.
    tak1313 likes this.
  7. Jan 14, 2022 at 12:30 PM
    #187
    tak1313
    2013 Base 2WD
    I know it's a series resistor but was wondering why it's in the duct stream, so thought maybe the the solder blob I was seeing in part images was some kind of sensor thingy since it appeared to be exposed compared to the rest of the part that would sit in the duct.
    It works - I can adjust the heat blending and the move the air from vent to floor to defrost, etc. Just seems to be weak in the first two settings. I can even hear that the fan speed jumps quite a bit from 2-3, at least more than I would expect from a one-step jump. I'll check all the motors/servos/door as well.
    I'll probably not get to it until it warms up though since it works decently enough - of course now that I have put this in print, it's going to crap out...
  8. Jan 14, 2022 at 12:31 PM
    #188
    tak1313
    2013 Base 2WD
    Thanks both. That's good to know as well.
  9. Jan 14, 2022 at 12:41 PM
    #189
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Just did mine!
    Did the resistor and connection.
    Used the denso one on Amazon like 20$ I think.
    Didn’t realize the fan would run on hi without the resistor even being connected.
  10. Jan 14, 2022 at 8:37 PM
    #190
    bagleboy
    Scott
    Norcal, Santa Rosa
    The resistor module has 3 strips of nichrome of differing lengths on an insulated plate so it gets really hot which is why it’s in the stream of air before the heater core. High bypasses the module which is why the blower still works even when the module terminals are cooked. As with the heated seats modules the terminals might be rated for the current but should have been derated for the excessive heat and heavier duty ones used or a larger heat sink plate used instead.
  11. Jan 27, 2022 at 7:42 PM
    #191
    JDM
    JDM Well-Known Member
    Jimmy
    CO
    2009 DCSB TRD OR S/C
    TRD supercharger, TRD exhaust, skids, sliders
    Yet another "fan working only on high" situation that led me here. Having dealt with blower motor resistor issues in other vehicles, to include bad contacts, I was glad to have been reminded of this (since it's been 20+ years since I've dealt with one). After checking out much of this thread, I started with checking the wiring, plug and terminals. Wiring showed some signs of heat, plug had a tan spot on it, and I could see a couple of the terminals did not appear to be contacting as well as they could. Popped out the worst ones (one being where the tan spot was) using a small cotter pin that fit into the slot where you release them, and gave the terminals some tweaking to create a better union to the pins. For now, I'm back to having all speeds.
    If it continues to be a problem, all the info in here will make it easy to swap out the plug and resistor for a different style that hopefully lasts longer.
    Thanks everyone for contributing.
  12. Feb 7, 2022 at 5:34 PM
    #192
    Navy Goat
    Navy Goat Member
    Oak Harbor, WA
    2011 Silver Tacoma double cab
    :thumbsup: Thanks for to this post I was able to upgrade and get it done within 30 minutes! Thank you!:oldglory:
    llibrm likes this.
  13. Jul 14, 2022 at 10:45 PM
    #193
    mattski81
    mattski81 Well-Known Member
    BC, Canada
    2007 Tacoma DCLB TRD OR
    Bit the bullet and installed the updated version from Toyota. Works well, lets hope it doesnt have the same problems... this is my 3rd now.
  14. Jul 17, 2022 at 3:16 PM
    #194
    Sidney Vicious
    Sidney Vicious Well-Known Member
    NOLAUSA
    2013 Black DCSB Prerunner
    Mine started acting up two years ago - it’s a 2013 - ordered the replacement part - and it went back to working like normal - recently acted up again- looked at changing it - tugged on wires in figuring it out - and it’s working again - so I will leave it be for another 2 years …
  15. Jul 18, 2022 at 5:44 AM
    #195
    tak1313
    2013 Base 2WD
    When you last changed it, was it the "new" version or the old version?
  16. Jul 18, 2022 at 5:13 PM
    #196
    Sidney Vicious
    NOLAUSA
    I never changed it - I jostled the one in the truck in the course of replacing it and apparently “fixed” the connection
  17. Aug 29, 2022 at 7:55 AM
    #197
    REAL_OG
    REAL_OG Well-Known Member
    does anyone know what the new design connection colors match is?? Since we’re have different colors?? I just bought this kit but don’t know how to match the right wire colors together
  18. Aug 29, 2022 at 9:04 AM
    #198
    tak1313
    2013 Base 2WD
    The new resistor/connector/wiring matchup is in the TSB
    Jimmyh and tacoman45 like this.
  19. Aug 29, 2022 at 10:31 AM
    #199
    REAL_OG
    Awesome thank you!!
  20. Aug 29, 2022 at 6:29 PM
    #200
    REAL_OG
    Well it looks like my blower resistor and pigtail is good if anyone wants to buy the new oem resistor and pigtail it from me for $45 includes shipping.
    My panel connection was actually fried . So I need to replace this instead
