Replacement of HVAC Blower Motor Resistor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garyods, Apr 26, 2008.
  1. May 31, 2013 at 4:07 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    This site had the best price and shipping.
    Marc70 likes this.
  2. Jun 30, 2013 at 1:37 PM
    Databox
    Databox Well-Known Member
    Fernandina Beach, FL
    2007 TRD Sport SR5
    Rims and Tires
    awesome write up.
  3. Jul 1, 2013 at 5:24 AM
    fla taco
    fla taco Well-Known Member
    Central Florida
    05 Dblcab TRD OR
    Great write up. Sub'd for later use.
  4. Jul 9, 2013 at 4:17 PM
    tacomalimited
    tacomalimited Well-Known Member
    Northern NJ
    2018 tacoma limited double cab Short bed 4x4.
    :eek:$1200 as opposed to $38 for the Colorado's??!!!?? I'm starting to think I should have kept my Colorado and never bought this truck!!!! I might have to sell/trade it in before my warranty expires!!!! That price is absurd!!!! Excellent right up btw op, thank you! I'll keep this just in case! :thumbsup:
  5. Aug 10, 2013 at 2:44 PM
    NightShades
    NightShades Well-Known Member
    Tallahassee, FL
    05 PreRunner
    Bug Deflector, Bed Extender, Roof Racks
    So i had this done, they also updated the wiring harness.. problem is... it turned off while i was driving
  6. Aug 10, 2013 at 2:44 PM
    NightShades
    Tallahassee, FL
    05 PreRunner
    So it is not fixed... now what?
  7. Aug 10, 2013 at 6:25 PM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2017 Tundra 5.7L
    Thanks, I recently did this in my old accord.
  8. Nov 3, 2013 at 8:35 AM
    mueller
    mueller Member
    joe
    riverside, ca
    blue 08 4dr prerunner sr5
    Fixed it, thx
  9. Nov 8, 2013 at 9:25 AM
    mgfab3
    mgfab3 Well-Known Member
    can always count on TW for the answers. I just unplugged and plugged back and its fine now.
  10. Nov 8, 2013 at 9:38 AM
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    There is a TSB for this. My dealer did the TSB for just over $200 (I was out of warranty). Yeah, I could have saved some money by doing it myself - but I'm lazy. $1200? Ri-fooking-diculous.
  11. Dec 24, 2013 at 10:05 PM
    wesleyelam
    wesleyelam New Member
    Wesley
    05 tacoma prerunner
    My heat and air used to work only on high but now it doesn't work on any speeds. The fan does not blow any air whatsoever. Would it be the resistor causing that or something else?
  12. Dec 24, 2013 at 10:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    That resistor change out is usually the problem. Check the plug first to make sure it is connected properly.
    This is pretty easy to do. Just takes some bending oround to get a good look under the dash.
  13. Jun 6, 2014 at 3:30 PM
    garrettc134
    garrettc134 Active Member
    Just replaced this in my 05. Worked like a champ. As a note for others - the new resister I got from the dealership (~$35) looked way more like a circuit board than a resistor, aka it was different from the original. Hopefully their redesign of the part makes it last longer!
  14. Jul 5, 2014 at 12:19 PM
    sixonthefloor
    sixonthefloor Active Member
    Orange Park, Florida
    Silver 05 Tacoma Sport 4x4
    3" Toytec Lift w/Nitto Terra Grapplers ATs on Enkei 17x8 wheels, custom 2 tone leather, DVD headrests, AVICZ-2 Nav unit with Blue tooth/rearview back-up and XM radio, PIAA 550 lights, TRD intake w/ AFE dryflow and wrap, TRD exhaust, PIAA back-up and bed lights and Grillcraft from hood scoop to bumper.
    I just did mine today. Very easy to do
  15. Jul 5, 2014 at 6:28 PM
    #35
    Humpty Dumpty
    Humpty Dumpty Member
    Kingston, Ontario, Canada
    '11 4X2 2.7L 5spd BASE Barcelona red
    Trifecta Tonneau cover, Class IV hitch, Always-on acc. outlet, OEM delay wipers, Keyless entry/remote start
    Don't count on it lasting, after 3 years my 2011 newer design "resistor" is shot, there was something on the board that is just melted. Ordered a new ceramic coated "improved design" after-market for $25 so I hope it lasts as this seems a little pathetic for a Toyota. Thanks for the thread so I could locate it!
  16. Jul 5, 2014 at 9:13 PM
    #36
    AZM9
    AZM9 Well-Known Member
    Jay
    Chandler, AZ
    2009 Prerunner TRD Sport
    ARE tonneau cover, Redline hood struts, Leaf TSB, and Trans TSB, Satoshi grille.
    Toyota has a TSB for this and requires that you splice in the new connector as well as replace the resistor. I paid $63.00 for the parts from Toyota, but it is the right way to do it because the connector itself under inspection has gotten hot and burned. It took me 20 to 30 minutes to do it myself but it is done right. I was pissed that as there is a TSB on it that Toyota still makes you buy the parts if you are out of warranty.
  17. Jul 6, 2014 at 8:13 AM
    #37
    garrettc134
    Link please? I might have to look up that TSB if this happens again.
  18. Jul 7, 2014 at 3:50 PM
    #38
    Humpty Dumpty
    CMD-KY likes this.
  19. Sep 1, 2014 at 5:41 AM
    #39
    joey1946
    joey1946 Member
    joey
    Florida
    05 tacoma
    My 2005 had this problem back in December 2013. After reading this forum and several others I checked with the Toyota dealer. He quoted $40.80 for the resistor. I asked about a replacement wiring harness in case it was also needed. After spending several minutes in his books and on the phone said the Toyota wiring harness was not available but they were using a GM harness part #1530-6069 that worked fine. I believe it is an old Saturn part. Weird. I didn't get a price quote on the Saturn harness but am betting it wasn't $1200. BTW - the replacement resistor carries a different part number than the original so they did upgrade something. Old # 87138-04050 New# 87138-04052. As of this minute just unplugging, coating with grease, then plugging back in fixes it for about a month at a time. No tools required for this cheap fix.
  20. Sep 1, 2014 at 6:24 AM
    #40
    Sandman614
    Tim
    '06 SR5 Off Road
    I followed the TSB (I believe) and bought the new p/n resistor on ebay, a new plug from an electrical store (mouser/newark) and cut out the burnt section of wire and replaced it.
    That'll probably be your cheapest more permanent solution.
    #40
