Replacement of HVAC Blower Motor Resistor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garyods, Apr 26, 2008.
  1. Sep 1, 2014 at 7:19 AM
    #41
    Burnsy444
    Burnsy444 Active Member
    Virginia
    07 Taco doublecab 4x4 sport
    grill guard winch Baja Roof Rack 4 Hella Black Magics 2 Hella Floods 3" leveling lift BFG AT'S Ultra Wheel Gauntlett Wheels Weather Tech mats Debaged Rebadged on the tailgate
    Check the connector. I made a post on page 1 check it out!!!
  2. Sep 12, 2014 at 5:04 PM
    #42
    Humpty Dumpty
    Humpty Dumpty Member
    Kingston, Ontario, Canada
    '11 4X2 2.7L 5spd BASE Barcelona red
    Trifecta Tonneau cover, Class IV hitch, Always-on acc. outlet, OEM delay wipers, Keyless entry/remote start
    Well the improved design blew after only 2 months! I'm trying to get it replaced under warranty, if not I might try a Toyota part. The supposed ceramic coating was just a dab of silicone, I just peeled it back and yup the little resistor is melted. BTW, I do NOT have a wiring or harness issue.
  3. Dec 24, 2014 at 10:42 AM
    #43
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    My 2010 Tacoma (71,000 miles) has had the blower motor a couple times only work on the highest speed, but back to normal (working all speeds) after a couple hours. Yesterday, 3 months later it did it again. The first product failure on my 2010, perhaps?
    What's the opinion as to getting a new resistor, Rock Auto, Toyota dealer, ??
  4. Dec 24, 2014 at 11:04 AM
    #44
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    ^Well, based on Humpty Dumpty's posts I'd just get the OEM Denso resistor. The supposedly better Airtex P/N 4P1650 appears to be just hollow marketing-speak.
  5. Dec 24, 2014 at 1:47 PM
    #45
    David K
    Well, it couldn't be any easier to find! Just look up from where a passenger's left toe is pointing to!
    Sure enough, a burn color on the plastic housing.
  6. Dec 30, 2014 at 9:40 AM
    #46
    David K
    OK, so I plug it back in after I took the photos above and the fan works at all speeds again. Is the resistor really bad or just a connection issue?
  7. Dec 31, 2014 at 7:00 AM
    #47
    Kenobe
    Kenobe Well-Known Member
    Ken
    Colorado Springs, CO
    09 Tacoma TRD Sport
    From your own pic you can see the toasted wire. The wiring for the blower was too small a gauge. Only by using a larger gauge, as identified in the TSB, will you be 100%.
    In your current situation your fan will work for a while but will go out again. The worry is with that wire getting so hot, it will certainly melt at some point and possibly even start a fire.
    Again, the TSB (T-SB-0149-11) can be found here on Tacomaworld.com. Another link:
    http://www.tacomahq.com/1089/broken-fan-tacoma-heater-air-conditioner/
  8. Jan 1, 2015 at 10:22 AM
    #48
    David K
    Thank you for clarifying. The issue didn't begin to happen until this last year, and my truck is 5 years old with 70,000 miles. I am assuming the TSB is not a recall, so no warranty for me, yes?
  9. Jan 2, 2015 at 3:31 AM
    #49
    Burnsy444
    Virginia
    This connector has ports which make connection via spring pressure. now if yours looks like mine and you can very easily see which line is burned, chances are the connection in there is not tight enough making for a loose or bad connection hence where the heat comes from. Solution? get something very small and gently lift the the connector to create a tighter connection. Re-install the resistor and BAM no more intermittence. This may not be the case for all but certainly worth attempting before ordering a new resistor! The connection being loose is the culprit. That's what causes the heat, and why the wire is burned. If the gauge was too small this would have happened in less that 1000 miles.
  10. Jan 2, 2015 at 3:39 AM
    #50
    Burnsy444
    Virginia
    David K if you have t seen my post on page one you shod check it out. I had the exact same issue. Fixed mine by bending the pin over a year ago still works fine.
  11. Jan 2, 2015 at 8:42 AM
    #51
    David K
    Thanks... do you have any photos of this "lift the connector" step?
  12. Jan 5, 2015 at 2:55 PM
    #52
    KenLyns
    Belly of the Beast
    According to the TSB, under-sized wire is not the problem. The root cause is bad dimensional control in the (Delphi) resistor receptacle, causing poor fitment of the harness connector in the receptacle and arcing. The improved (Denso) resistor has tighter dimensional control of the receptacle.
    Note the replacement pigtail has the same connector and same sized wire as before.
  13. Jan 7, 2015 at 9:22 AM
    #53
    David K
    Thanks Ken.
  14. Jan 26, 2015 at 3:49 PM
    #54
    07terry
    07terry Active Member
    north carolina
    07 4x4 trd
    i have a 07 tacoma and my wife was driving it over the week end and the fan worked fine, today it woudnt work at al,l we have to use my truck because my chair lift is on it and we really need the heat
  15. Jan 26, 2015 at 3:49 PM
    #55
    07terry
    north carolina
    07 4x4 trd
    also someone checked the connector no difference ?
  16. Feb 28, 2015 at 11:41 AM
    #56
    rlpayne88
    rlpayne88 New Member
    roger
    chanute is.
    07 4x4
    Gary its people like you saving people like me tons of cash. Sure enough on my 07 it was a single connector in the resistor harness causing it to malfunction. I just cleaned and used used the proper grease and it works fine. If anyone does need the new pigtail , eBay offers the new pigtail along with the resistor for under forty dollars now. Its a long way from 1200$. My local dealer wanted 124.00 for the resistor and two hours labor for fixing this problem. Again thanks for writing suck a good article along with great pics. Roger
    #56
  17. Apr 22, 2015 at 4:58 PM
    #57
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Need to check mine too . Also wire connector at climate control switch overheating too. Will try to bend tab to tighten connection.
    Jeff Lange likes this.
  18. Apr 22, 2015 at 5:03 PM
    #58
    33harman
    33harman Well-Known Member
    Florida
    07 PreRunner TRD Sport
    3" toytec/bilstein lift with aal, light racing uca, 285/70/17 hankook mtrt03, SCS sr8 matte gun metal wheels, Rockford fosgate 6X9 speakers, jvc 6" display, uws low pro toolbox, weather tech digital fit, 15% tint, spidertrax 1.25" spacers, Tacotunes 10" box powered by 350w sound ordinance amp.
    Awesome Post, Thanks so much.
  19. Jun 9, 2015 at 12:01 AM
    #59
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    I have this same discoloration too...did your turn out to be the resistor causing the discoloration?
    Had any issues with your ign 1 no. 2 fuse blowing by chance too?
  20. Jun 24, 2015 at 5:43 PM
    #60
    gefrorenertau
    gefrorenertau Speak German - will travel.
    SoCO
    '13 4Runner SR5
    Did this today, the most time spent was going to get that silly 5.5mm socket.
    Thanks a lot OP for writing this up!
