Replacement of HVAC Blower Motor Resistor
Discussion in '2nd Gen. Tacomas (2005-2015)' started by garyods, Apr 26, 2008.
  1. Jun 24, 2015 at 5:44 PM
    #61
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Cheap Walmart socket sets have the 5.5mm
  2. Jun 25, 2015 at 8:47 AM
    #62
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    So far, by just giving a little push on the wires, the couple times the the blower fan stops at number 1, 2, or 3 speed, and the fan works.
  3. Jul 9, 2015 at 3:07 PM
    #63
    Manwithoutaplan
    ID
  4. Jul 9, 2015 at 6:13 PM
    #64
    Bogatzi
    Bogatzi Active Member
    Simcoe, Ontario
    2011 DCLB TRD Sport
    Here is a picture of a burnt resistor and a new one for my 2011.IMG_0015.jpgIMG_0014.jpg
  5. Jul 9, 2015 at 6:15 PM
    #65
    gefrorenertau
    gefrorenertau Speak German - will travel.
    SoCO
    '13 4Runner SR5
    How long did it hold up before burning out this time?
  6. Jul 9, 2015 at 6:21 PM
    #66
    Bogatzi
    Simcoe, Ontario
    2011 DCLB TRD Sport
    It is still working well. It burnt out because a chipmunk built a nest in the fan. Now when I turn the fan on, I listen for telltale signs of another nest being built. I have had to clean and replace the cabin air filter 3 more times.
  7. Jul 16, 2015 at 7:50 AM
    #67
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    Great info
    My kids 09 just started to do the high only deal.
    Thanks Chris 4X4 for the link to this thread!
  8. Jul 16, 2015 at 5:37 PM
    #68
    kurt leong
    kurt leong New Member
    kurt
    Red 2008 Tacoma Reg. cab 2x4
    Thanks! My fan only blew on high.........I found the resistor harness and shook it in place and it works 100% now, just like that!!!!!! Awesome!!
  9. Jul 16, 2015 at 6:44 PM
    #69
    David K
    Yup, same here... I have had to wiggle it about three times the past year.
  10. Jul 16, 2015 at 6:49 PM
    #70
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  11. Jul 16, 2015 at 6:51 PM
    #71
    David K
  12. Dec 19, 2015 at 10:14 PM
    #72
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Thanks for this thread! I was in and out within an hour-including p/u of parts.
    5.5 == 7/32 more or less...
  13. Feb 12, 2016 at 12:17 PM
    #73
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    Great post. Just today, my blower decided to only blow on high. Quick search on TacomaWorld brought me here and a lil wiggle of the connector and I'm blowin like a mofo. Thank you VERY MUCH! :thumbsup::thumbsup:
  14. Feb 25, 2016 at 8:22 AM
    #74
    Mom2Wesley
    Mom2Wesley New Member
    Susie
    2005 Toyota Tacoma 4wd double cab
    Thank you so much for this post! I have 05 Tacoma, had a 97 before this. In both trucks have had to replace ac blower motor more than once. In fact I was pleased they made it so accessible in the 05 model. Anyway, I knew this time was different because it was still blowing but only worked on high. After reading this post I looked under there and the floor mat was jammed up against the resistor. I pulled the mat back where it goes and pulled the resistor wires up a bit, back where they go and tada! Thank you so much!
  15. Apr 11, 2016 at 6:40 PM
    #75
    ionyota
    ionyota Well-Known Member
    2012 TRDOF DCSB
    OME lift, All-Pro UCAs, BFG KM2 pizza cutters
    @garyods - You are my hero tonight! Thanks to your pictures and explanation I had my blower motor resistor replaced in less than 10 minutes. Found the part on Amazon for $25. Dealer probably would have charged $150 - $200 for that job.
  16. Apr 14, 2016 at 2:03 PM
    #76
    Icecold
    Icecold New Member
    2005 Tocoma SRS 2WD
    THANKS! I own a 2005 Tocoma and the resistor and wire went bad. I would recommend using an automatic wire stripper and i used butt connectors to splice the wires together.
  17. Apr 14, 2016 at 2:19 PM
    #77
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I have actually read several comments mentioning the resistor nor the plug is the problem. It's actually the pins inside the resistor which are too narrow and don't make sufficient contact with the plug. It makes sense to me and I could see why they would be causing the resistor to burn out due to lack of consuctivity from a proper contact connection from within.
    While they sit like this - - - - the issue could easily be improved upon when replacing the burnt up resistor with the new one by taking some needlenose pliers and tweak the pins so they are no longer straight and make better contact on the connector by making them sit like this / / / / .... not to such an extreme obviously, but just enough to allow a better contact to the resistor pins to the plug. Apply dielectric grease to the plug and resistor pins as well to allow for better conductivity. You should not have the problem again.
    06Tacooo likes this.
  18. Apr 22, 2016 at 11:38 PM
    #78
    Goblin
    Goblin TSB 0305-08 Rev2 & TSB 0373-09 DONE
    VA
    09 SR5 TRD OFF ROAD
    STOCK TRD 4X4 OR DC
    I was lazy and had the dealer change out my resistor because my fan would not work on HIGH? They did it at no charge saying there was a TSB. Hm? Anyhoo, it did not fix the problem. I pulled out the climate controls and realized they were also burnt. Ordered a new to me climate control off eBay for $73 and that fixed it. Still need to change out the burnt plug.
    #78
  19. Apr 23, 2016 at 7:39 AM
    #79
    Tex-Tac
    Tex-Tac Well-Known Member
    TEXAS
    2008 Tacoma V6 PreRunner SR5 Extended Double Cab Desert Sand Mica
    Installed Overhead Compass and Temperature Display along with outside temperature sensor and wiring; LED lights reverse backup; LED license plate lights; Added GTA Bluetooth Audio kit to stock radio for iphone audio; Spare tire steel braided air hose extension connection to rear bumper; Installed new headlights along with new bulbs PIAA H4 XTreme and for fog lights PIAA H10 XTreme bulbs. Installed new hood with "hood-scoop". Installed Predator Side Steps. Replaced front chrome grill with customized color matched (Desert Sand Mica) grill with added TOYOTA lettering (also in matched color), installed and secured tailgate anti-theft devices. Also installed a new external TPMS monitor for all 4 tires.
  20. Sep 18, 2016 at 9:26 PM
    #80
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Anyone have a link for a 2011 resistor? Thanks
