Replacement Radiator Options???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ace115, Dec 30, 2017.
  1. Mar 17, 2018 at 9:18 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    I just want to make a small update. I ordered the mishimoto radiator, its made in china and its basically as good as any other china radiator. I dont have high hopes.
    opteron likes this.
  2. Mar 19, 2018 at 5:46 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Been running that one on my 93 for 6 yrs live it cools better. But i also did a reverse flow on the coolant because of the exhaust cross tube right next to the heads.
    OneWheelPeel[QUOTED] likes this.
  3. Mar 19, 2018 at 6:55 PM
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Champion makes an all aluminum radiator for our trucks
    QMEDJoe likes this.
  4. Mar 20, 2018 at 12:37 PM
    OneWheelPeel
    Phoenix, AZ
    Its a great looking unit but I dont need a radiator that is double the price, Rated for 600 horsepower or to look like Liberace climbed under my hood.
  5. Mar 20, 2018 at 1:11 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    I bought one but haven’t been able to install it yet.
  6. Mar 20, 2018 at 2:09 PM
    zach141b
    zach141b Well-Known Member
    Zach
    Louisiana
    2001, double cab, 4WD, 3.4L Tacoma
    I was gonna say, there was a thread on the Champion not too long ago.
    Running Board Man likes this.
  7. Mar 27, 2019 at 5:36 PM
    pullingin
    pullingin Well-Known Member
    @Timmah!
    I have been looking around for an OEM and all part stores say it is discontinued. Do you know where I could find an OEM?
    Laz likes this.
  8. Mar 27, 2019 at 8:35 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    The last one I got from Camelback Toyota last year for my 98 4runner was different than the one I bought for 2000 4unner around 5 years ago. The one I got 5 years ago looked identical to my original radiator and it cost around $200. The one I got last year cost only around $120 but it definitely looked different and it felt cheaper. The trans cooler fittings seemed flimsier and the drain no longer had the nice little hole to direct the stream of coolant straight downward. Now it just dribbles out the plastic threads. I guess whoever was the supplier stopped making them for whatever reason. Kind of a bummer. I don't plan on using this radiator for any further than 100k miles and then I'll get another one for extra insurance.
  9. Mar 27, 2019 at 9:19 PM
    Tacoma Cutout
    Tacoma Cutout Well-Known Member
    I am going to call Champion tomorrow. Their an hour and 20 minutes away. The Autozone radiator I bought, WILL NOT line up with the original mounting holes (98 taco, 2.4L)... The core alone is 3/8" wider than oem, height is okay at 18-11/16"
  10. Mar 28, 2019 at 6:00 AM
    Aagill225
    Aagill225 Well-Known Member
    Arthur
    2004 Tacoma PreRunner
    None
    I got mine from Amazon. It was like $100 almost 1.5 years ago. Put almost 30k miles through it already. No issues no probalems at all. If I remember correctly the mounting bracket was off by a C-hair. Works great and was cheap. No core charge either!!
  11. Mar 28, 2019 at 6:00 AM
    Aagill225
    Arthur
    None
  12. Mar 28, 2019 at 6:02 AM
    Aagill225
    Arthur
    None
    I also had very good luck with Hawkins radiator (radiator.com I beileve) resonabale and their Warrentees are 50 state valid. Like discount tire. You can take it to any shop on their list to get it replaced under warrantee
  13. Mar 28, 2019 at 1:32 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    My last one everything has New Radiators Was from Radiator Barn just how long have they been gone?
    I like my Copper and Brass ones
  14. Jan 19, 2020 at 10:56 AM
    Arctic Taco
    Arctic Taco Firefly, Serenity Ed. -Arctic Taco, a slow build
    Denali Park, Alaska
    98 Tacoma Xtra Cab DLX, 85 Toyota LWB 4x4
    dents and missing bits, built in the Gravel garage, hillbilly trained mechanic…
    To avoid the bottom tank exposure you need a radiator for a RWD, I am running the Champion CC1778, for about a year and a half, bought 3 yrs ago. Have heard about some quality control issues on the construction (3 row) with failures happening after about 25-35k miles. So I’m still searching for a possible upgrade, with fingers crossed.
  15. Jan 19, 2020 at 12:42 PM
    #35
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    You can't buy OEM any longer. They came with Harrisons. I met a guy a couple weeks ago still running his from '98. To me that would be scarier than a 100 dollar O'Really's.
  16. Jan 19, 2020 at 3:37 PM
    #36
    Good deal
    Good deal Well-Known Member
    Texas
    Replaced mine with a Spectra Premium B1778 for about 100 bucks. Because mine is a MTX I capped off the port that runs to cool ATX(s).
  17. Aug 6, 2020 at 12:10 PM
    #37
    slodoug
    slodoug Well-Known Member
    question: since i have a stick, mine doesnt have the transmission cooler on bottom. Do i need to look for one without it or just not use it if it comes with one?
  18. Aug 6, 2020 at 12:16 PM
    #38
    Wyoming09
    New Tripoli Pa
    Super Springs
    Most Aftermarket radiators Come with the Cooler not much you can do it won`t hurt anything.
    If you can find one without the cooler go for it one less then to fail
  19. Aug 6, 2020 at 12:30 PM
    #39
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    The stick shift rads will be shorter and have no tranny cooler. I like them better because they dont hang as low. I toss my skid plate the 1st oil change. I prefer a stand alone tranny cooler.
  20. Aug 6, 2020 at 11:16 PM
    #40
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    I just installed the Koyorad for a 3rd gen 4runner iny truck. Very happy with it. There's more info about it in the champion rad thread. It doesn't have an internal trans cooler.20200803_184247.jpg
