Replacement Shocks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jnippers92, Oct 28, 2016.
  1. Oct 28, 2016 at 6:46 PM
    jnippers92
    jnippers92 [OP] New Member
    Joshua
    2012 Toyota Tacoma Pre-Runner V6
    I've noticed some squeaking when riding on rough roads, and I'm thinking my shocks (which have never been replaced, 134,xxx on the odometer) need to be replaced. My truck never leaves the road unless I park in the yard, so I don't need anything for off-road use.
    I'm looking for something that will have a smooth ride. My truck is my daily driver, and I'm usually running 65-80 mph.
  2. Oct 28, 2016 at 9:22 PM
    08tacobear
    08tacobear Well-Known Member
    08 taco DCSB pre runner V-6 SR5
    12v accessory plug right rear bed bin,1gallon air compressor setup in left rear bed bin, 3-window bed topper.
    I was in the same boat (except info haul and tow) but from lurking and reading most will recommend as I do now what is affectionately referred to as 5100s Bilstein 5100 on all four corners.or OME (Old man Emu) but they are skirt more cost and frankly I love my Bilsteins a little better than stock. Keep your stock front springs. Hopefully you have had the recall on the rest leafs Completed.
    Rear shocks:
    http://www.headstrongoffroad.com/store/p269/RCD/Bilstein_5100_Rear_Shock_(PAIR)_-_D559/D560.html
    Front shock replacement
    http://www.headstrongoffroad.com/st...air)_-_24-263108_for_2016__Toyota_Tacoma.html
  3. Oct 29, 2016 at 6:37 PM
    missioncruiser
    missioncruiser Member
    Mission BC
    2013 SR5 DBL Cab 4WD
    My friend just got a quote to change his stock fronts to bilstein 5100s and the shopped warned him it could be an extra $1000 if the cams are rusted and frozen? His is an 08 with 200,000km but I wasn't sure what parts he was referring to? Something to do with removing the coils perhaps? Any ideas?
  4. Oct 29, 2016 at 6:48 PM
    Pigpen
    Dan
    Northwest Montana
    It's the lower control arm bolts. Mine were seized on my 2012. That's not a terrible price.
