Replacement Shocks
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RyanFMD, Jan 29, 2025.
  1. Jan 29, 2025 at 2:49 PM
    RyanFMD
    RyanFMD [OP] Well-Known Member
    2018 Quicksand TRD Off-Road
    Hey guys!
    I have a 2018 TRD Off-road that I took to the dealer and found my rear shocks are leaking badly. The truck is just shy of 100K miles and I guess I need a replacement set. The dealer would replace with OEM. Another shop that people have recommended to me quoted me only about 100 bucks cheaper but is trying to sell me “VSV Shocks.”
    I can’t really find any info on them, but the mechanic insists and says they are better and have a 3 year warranty. The only info I did find was from a forum that said they’re the OEM for Autoparts International and most likely cheap Chinese parts. Just wanted to ask the experts here and see what y’all recommend for replacements. The truck is a daily drive and lives on pavement 90% of the time.
    Somebody did also recommend to me Bilstein 5100 for the rear but I wasn’t sure if I needed any upgrades to run those.
    Thanks!
    TacoTime55 likes this.
  2. Jan 29, 2025 at 2:51 PM
    Clearwater Bill
    Billy
    Largo Florida
    No upgrade needed.
    For whatever your choice, it's a short job lying in the garage floor with basic hand tools.
    No need to pay shop fees, easier than an oil change.
  3. Jan 29, 2025 at 2:51 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    bilstein 4600
    JFriday1 and Clearwater Bill like this.
  4. Jan 29, 2025 at 4:28 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    TS4x4 and RIX TUX like this.
  5. Jan 29, 2025 at 5:16 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
  6. Jan 29, 2025 at 5:23 PM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    This job is much simpler than doing the front shocks.
    Not as messy as an oil change.
    https://www.youtube.com/watch?v=c3oiM4xNO6o
    Tocamo and eurowner like this.
  7. Jan 29, 2025 at 5:37 PM
    MGMDesertTaco
  8. Jan 29, 2025 at 8:22 PM
    devinzz1
    devin
    2023 aclb trd or mt
    op said rear shocks specifically. which yea. unless your in the rust belt and that top nut is siezed its pretty basic. even the front is basic. idk why people use those sketch spring compressors when you can just release the spring pressure on the truck itself without any special tools
  9. Jan 30, 2025 at 5:13 AM
    wake100
    wake100 Well-Known Member
    Syracuse, NY
    2021 AG DCLB off road 4x4
    Uptop roof rack, cali raised light bar, diamondback tonneau
    its so weird to call people out yet not actually read the issue yourself...
  10. Jan 30, 2025 at 5:21 AM
    TS4x4
    TS4x4 Well-Known Member
    2018 TRD Offroad
    Stupidly dangerous. If you underestimate the tension still left in the spring (which is easy to do), once the nut is loose enough it undergoes explosive decompression and your spring or hardware goes flying with the force of a bullet, your jack slips and truck rolls, you get seriously injured or killed by one or both of those things.
    Can you do it? Sure. You can also skydive without a parachute. Only works once though.
    Edit: I've done my entire suspension twice now, which includes the entire shock assemblies. The rear is different since the shock isn't under tension, its more or less hanging there. The front though? hell naw. Pay the extra $50 for preassembled springs or take it to a shop. I would NEVER use the truck's weight as a spring compressor.
    TacoTime55 and TacoManOne like this.
  11. Jan 30, 2025 at 5:36 AM
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    Preassembled is the only way to go and makes the job faster and the parts are put on in the correct order. No need to worry about what goes where in the stack.
    TS4x4[QUOTED] likes this.
  12. Jan 30, 2025 at 7:26 AM
    devinzz1
    devin
    2023 aclb trd or mt
    what? truck on jackstands. hydraulic jack under the lca with strut still bolted into place. undo top shock nut and lower ball joint. slowly lower the jack and all temsion is released. the coil physically cant even pop out at this point and il argue any day of the week that its safer than those sketchy coil compressors on a 700lb spring rate coil. it is the only method i use at this point
  13. Jan 30, 2025 at 8:06 AM
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Your sentiments are definitely on my mind.
    Can I do it?
    With lots of confidence, sure.
    But if something goes wrong?
    I'd feel better having the shop/dealership do the work and cry once.
  14. Jan 30, 2025 at 8:09 AM
    Methadras
    Methadras Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    Fox 2.0, not super expensive. Probably $160-$170 depending on where you go. Good ride characteristics for the rears. Fairly easy install if you have a jack and tools.
  15. Jan 30, 2025 at 8:41 AM
    Garymvvvvvv
    Garymvvvvvv It's easier to get forgiveness, than permission.
    Gary
    La Grange Texas
    2022 Tacoma SR5
    TRD pro grill, Raptor Grill Lights, 2 color fog lights, rock flood lights, light bar with powder coated front bumper, X-Bull winch, K&N cold air intake, RIPP ignition coils, oil catch can, E3 iridium spark plugs, 275/70 R17 BFG KO3 tires, OPT7 tail gate light bar, black out mirror caps and rear bumper caps, sprint booster, LED interior-exterior light bulbs. Flashing 3rd brake light, infinity tail lights and Alpha Rex Nova black headlights, Seat covers, Mr. hood scoop with 18 inch amber light bar inside. 2 inch lift front/rear. 1.5 inch wheel spacers. Fender flares,
    I'll agree with some of the posts. Pre assembled spring/shock assembly would be your safest bet. However I just installed 2" OME springs and Bilstein 5100 shocks on my 2022 SR5 and used the floor jack method for spring decompression. Jack stands with the E-Brake on and wheel chocks kept everything stable. The hardest part was actually putting that 500 lb (LOL) tire back on the truck. I feel ashamed when I watch a video and some small person simply picks up a tire and lifts it on. :)
  16. Jan 30, 2025 at 8:44 AM
    Garymvvvvvv
    Gary
    La Grange Texas
    2022 Tacoma SR5
    Team oil drop has the easiest video for front end springs/shocks installation
    Soft Taco and TacoManOne like this.
