Replacement spare tire/wheel
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Knoxes, Mar 10, 2022.
  1. Mar 10, 2022 at 7:12 AM
    Knoxes
    Knoxes [OP] Active Member
    2022 TRD OR DCLB
    We just picked up a 2005 base Tacoma for my son. It didn't have a spare when we bought it and before I had a chance to research, he got a flat. The tires on it are 215/70/15. Is the spare a donut? And what's the best source for quick replacement? I guess I'd need the wheel specs and lug pattern for a full size spare, right?
  2. Mar 10, 2022 at 7:15 AM
    reallifedog
    reallifedog wat.
    Jordan
    Denver
    08 Tacoma TRD OR
    The spare is full size but I didn't think you could fit 15s over the front rotors so I'm kind of at a loss here. The lug pattern is 6x5.5 and is typically a 16" wheel
  3. Mar 10, 2022 at 7:17 AM
    GARSHA91
    GARSHA91 YES, that is me on that Facebook group
    Chicago
    2015 TRD Off-Road DCSB
    Just a grocery getter
    What reallifedog said. If the tires are old id opt to replace all 4 and get a 5th for the spare. Pick up a steel wheel to put the spare on and it goes under the bed.
  4. Mar 10, 2022 at 7:17 AM
    guyfromky
    guyfromky Well-Known Member
    I don't believe the spares are donuts. At least mine isn't. The size of your spare would just need to match the size of the wheels and tires currently on the truck if that is what you intend on keeping on it. The bolt pattern is 6x139.7 (6x5.5), unless you have a 5-lug, in which case it is 5x114.3 (5x4.5).
    TRDSport10 likes this.
  5. Mar 10, 2022 at 7:19 AM
    Brogie
    Brogie Well-Known Member
    Mark
    Columbus, OH
    2014 4wd standard cab silver sky
    It's a 5 lug based on the size. The spare is full sized. You can get a plain rim and tire from most tire shops such as Discount Tire.
    clifpaul, blu92in99 and wi_taco like this.
  6. Mar 10, 2022 at 7:28 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Try a scrap yard, or maybe a tire store. Make sure to check the date code on the tire to be sure it is less than 10 years old. About a year ago I picked up a used tire that was only 3 years old from a tire shop to replace my 15-year-old spare. The spare had only been on the ground for around 1000 miles.
    I'd also STRONGY suggest buying a set of tire plugs, tire repair tools and a small compressor that plugs into the cigarette lighter. Total cost will be well under $100. I keep one in every vehicle and over the last 20-30 years have plugged at least 20 tires. Mostly helping other people. It is a LOT easier, safer, and faster to plug the tire on the vehicle and air it back up than changing to the spare. Many times with a slow leak I've been able to just air it back up and get to a tire store and let them repair the tire. Other times I've had to plug it until I could get to a tire store. And other times what I did was enough.
    I've only had to resort to putting my spare on once in my nearly 50 years of driving. The hole was just too big to plug. In 2011 I ran over something and had a flat in Oklahoma. I was able to get 3 plugs in the tire, air it up enough to get me to the next exit and to a tire store. The tire was too damaged to repair, but the tire store used their rack to put my spare on and charged me $10. That was the 1000 miles I put on the Tacoma spare getting it home.
  7. Mar 10, 2022 at 8:42 AM
    Knoxes
    2022 TRD OR DCLB
    I called our local tire guy and he suggested a salvage yard nearby. I have a call into them. It would be great to be able to get a matching wheel, but only if it's cheaper than a steelie.
    Getting a plug kit would be a good idea. I've never done it, but watched it being done a couple of times. It can't be that hard. I haven't checked his tire yet to see what caused the flat, but it apparently went down over night, so it's gotta be a nail or something. New house being built down the street, too. That always concerns me.
  8. Mar 10, 2022 at 9:34 AM
    clifpaul
    clifpaul Well-Known Member
    North Texas
    06 access cab 5 lug
    Too many to fit here now!
    My 2006 5 lug came with a full size 15x7 steel rim with a 215/70r15 tire mounted on it. And someone feel free to correct me if I'm wrong, but I think certain Jeeps and mustangs ran the same 5X4.5 bolt pattern so you should have some options if you go the scrapyard route. And most defiantly invest in plugs and a good 12v air compressor. Two flats and 1 spare is never fun!
  9. Mar 10, 2022 at 9:35 AM
    guyfromky
    I would prefer to have a spare that is specifically hub-centric to the Tacoma.
    TRDSport10 and clifpaul[QUOTED] like this.
  10. Mar 10, 2022 at 9:41 AM
    clifpaul
    North Texas
    06 access cab 5 lug
    Not gonna argue there. I'm actually rather partial to the OEM steel rims.
  11. Mar 10, 2022 at 9:52 AM
    Clearwater Bill
    Billy
    Largo Florida
    Where are you located? I have an extra wheel available.
    They are 15 x 6 and you can go to a 235 x 75 tire with no fitment issues on the stock wheel.
    I gathered up a set of 'spare' wheels as I liked their look better than the ones on the ground. Added some trim rings. Just because.
    And we have a 5 lug forum you may have interest in.
    eherlihy, TRDSport10 and clifpaul like this.
  12. Mar 10, 2022 at 11:02 AM
    Knoxes
    2022 TRD OR DCLB
    Thanks, Bill. We're in NC and I think I can find one around here without too much difficulty, but I appreciate the offer. Still waiting to hear back from the salvage yard.
  13. Mar 10, 2022 at 4:51 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    EBay auto has posts on most spares so look them up if local does not come thru for you.
    Charlie Bravo likes this.
  14. Mar 14, 2022 at 11:01 AM
    Knoxes
    2022 TRD OR DCLB
    Just to update, the tire had very thin radian cut in the sidewall. So there wasn't really an option to plug it. The tire shop guys are always great. I had to take the cut tire up there, have them install a new tire, run back to the house to put it on, go back to the shop with the truck to do the other 3. All done within a couple of hours on a Friday afternoon. And they saved me the best of the used tires to put on a rim, once I find one.
