Replacement Steering pump and reservoir
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pacificclam, Oct 13, 2022.
  1. Oct 13, 2022 at 2:10 PM
    Pacificclam
    Pacificclam [OP] Well-Known Member
    Carl
    Hawaii
    2010 Tacoma 4x4 Access cab
    6” pro comp lift Kings Coils and Shocks 700lbs Element UCA Atlas Leaf spring kit 17x9 stealth custom series ray 10s -38 33x12.5 toyo open country mt Tom woods driveshaft CSF high performance radiator 4.88 GEARS
    Ive got a 2010 tacoma 2.7l 4cyl lifted about 6" running 33x12.5 tires on it. Ive been noticing some leaking from the steering pump / reservoir. It seems like i have more leakage after i go 4x4 vs just cruising in 2wd. Do I need to upgrade my steering pump to accommodate the larger tires? thanks!
