Replacement Tail Light
Discussion in '2nd Gen. Tacomas (2005-2015)' started by captainh00k, Oct 21, 2017.
  1. Oct 21, 2017 at 7:52 AM
    captainh00k
    captainh00k [OP] Well-Known Member
    Pittsburgh, PA
    2023 DCSB
    Hi,
    I recently purchased a 2012 and after getting home I noticed the right tail light has condensation in it. While I'll probably try and seal it first, I'm thinking to just replace the tail light since there is discoloration in the reverse light area of the lens from the condesation.
    Two questions:
    Since it seems to be a challenge finding a used OEM tail light, do the aftermarket direct replacement tail lights look the same? Or is there a slight difference in appearance?
    If there is a slight difference in appearance, is it worth replacing both tail lights? Are the non-OEM tail lights from ebay and Amazon worth it?
    Thanks in advance.
  2. Oct 21, 2017 at 8:06 AM
    batacoma
    batacoma Truck Wars
    2012 Regular Cab 4spd
    Most likely all aftermarket parts will look somewhat different than oe. After market would probably be a cheaper solution, and most likely are only sold in pairs.
    I have black depot led factorystyle taillights, I've read on here that they will most likely fail overtime, I think I got them off the Wal-Mart website for $130 I have the incandescent red taillights and are keeping them, so I can't help you with the replacement you need.
    Fitz235 likes this.
  3. Oct 21, 2017 at 8:07 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Quality wise from everything I've heard, and my own experience with them so far, Depo is the next best thing to OEM. Some have reported some leaking, but many have not. Mine are about a year old, been through the car wash a bunch of times with no issues.
    http://www.ebay.com/itm/like/401407404550?chn=ps&dispItem=1
    Plus, I love the way they look. OEM but better.
  4. Oct 21, 2017 at 8:09 AM
    Fitz235
    Rob
    New Hampshire
    Sounds like we think alike. I have my factory tails stored (just in case).
  5. Oct 21, 2017 at 8:49 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Go to www.rockauto.com Was able to buy a complete new assembly for $120.00. RockAuto gives you choices and info into each. Most cases you can get factory components. All Mfg's outsource the building of components.
  6. Oct 21, 2017 at 8:52 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    I have the Depo set. The look great and work great. I bought from that seller as well. A+
