Replacement Windoor
Discussion in 'Tonneau Covers, Caps and Shells' started by Logan.spencer, May 29, 2017.
  1. May 29, 2017 at 7:58 PM
    Logan.spencer
    Logan.spencer [OP] Well-Known Member
    Logan
    Southern VT
    '18 TRD OR DCSB Cement Manual
    2018 TRD OR DCSB 6 Speed MT Magnaflow Catback CBI T3 Front bumper RCI Skids (front, trans, t-case) RCI Rear Bumper (custom swivel recovery points) Rocky Road SuperSliders ARE Overland cap with area lighting Rigid SRQ backup lights Rigid DSS ditch lights Baja Designes 20" single row Baja Designs squadron sport fogs Icon Stage 9 SwitchPros power system ...i may be forgetting something...
    have any of you guys had to replace a Windoor on an ARE cap? how much did it cost you from ARE or what did you do instead of going through them. thanks!!
  2. May 29, 2017 at 8:01 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Is the frame damaged? If not I'd try a glass shop.
  3. May 29, 2017 at 8:09 PM
    Logan.spencer
    Logan
    Southern VT
    frame is fine. a tree snagged the latch and twisted it into the glass and it all shattered.
