Replacing 2015 sport with 3rd gen off road suspension
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chrisbr0vvn, Oct 17, 2023.
  1. Oct 17, 2023 at 7:45 PM
    Chrisbr0vvn
    Chrisbr0vvn [OP] Member
    I’m pretty sure I’ve read a ton of posts on here about this but for some reason I can’t find them and want to confirm my logic is sound.
    I just got a 2015 sport and am considering replacing the shocks with newer 3rd gen off road shocks (I found on marketplace for $100). From what I’ve gathered, it sounds like the 3rd gen off road has a nicer ride. I plan on eventually upgrading to some 5100s etc. but for the moment this seemed like a pretty cheap and easy way to get a nice upgrade in the mean time. Does this sound right?
    drizzoh and Island Cruiser like this.
  2. Oct 17, 2023 at 8:32 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    Yup that sounds right!
    Many members here have installed 3rd Gen suspension on their 2nd Gen. Reportedly it will lift the front about an inch
  3. Oct 17, 2023 at 8:35 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes do it, but if possible try to figure out which is left and right, there's colours on the springs that indicate this. They are rated different side to side to support the different weights.
    Rear shocks just bolt them in.
    TnShooter and Chrisbr0vvn[OP] like this.
  4. Oct 17, 2023 at 8:57 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
  5. Oct 18, 2023 at 7:52 AM
    Chrisbr0vvn
    Super helpful info thanks! I like how they change the colors... keeps things interesting lol
  6. Oct 18, 2023 at 9:18 AM
    Inavandownbytheriver
    Inavandownbytheriver Well-Known Member
    Earl
    2002 Toyota Tacoma trd
    Did that to mine recently, but mine is 15' OR. Was an easy swap.
  7. Oct 18, 2023 at 1:58 PM
    Revelations
    Revelations Well-Known Member
    2014 MGM DCSB
    Not if he's only replacing the shocks. The lift comes from the springs. I recently replaced my shocks with 3g OR shocks and they work just fine. I kinda don't like them because I'm used to the firm ride of the sport shocks. The OR shocks are a bit soft for my liking. But they were cheap and I don't have cash to spare.
  8. Oct 18, 2023 at 2:35 PM
    Island Cruiser
    Kauai
    Baja
    Understandable but I’ve only seen a handful a times people selling front shocks without springs. People replace the whole assembly usually.
  9. Oct 18, 2023 at 3:20 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    They will bolt right up. As stated if you are going to use the 3rd gen trd OR springs you will gain ~ 1in of lift up from from the springs. But if its just the shocks, your 2nd gen coils will go in no problem. For 100$ even if its just 4 lightly used shocks its a good cheap refresh.
  10. Oct 19, 2023 at 5:40 AM
    Revelations
    2014 MGM DCSB
    There is one guy who sells them as shocks only in the marketplace. I guess he works for a dealer or something. It's about to dry up if the 24 models have different chassis geometry. Also, there are plenty of people on fb who has shock only. Plus, for me, I bought some $35 spring compressors, so I can remove springs as necessary.
  11. Oct 19, 2023 at 8:29 AM
    nd4spdbh
    SoCal
    Suspension is 100% different on the 2024 trucks. There is a reason why I just refreshed my truck with 2023 take offs (UCA's, front TRD OR springs, rear leaf springs, and 5100's - fronts are 3rd gen part number- in all 4 corners).
    After selling off my SPC UCA's, OME leaf pack - that had 70k miles on it, 2nd gen 5100 fronts, 5125 rears (both with 40 k miles on them), as well as the 3rd gen TRD OR shocks i got as a set with the 3rd gen UCA's (as i went with new 5100's) AND adding in rear air bags for load handling.... I came up 20 bucks. Literally got paid to do a full suspension refresh on my truck haha.
  12. Oct 19, 2023 at 10:04 AM
    Revelations
    2014 MGM DCSB
    Yeah. The takeoffs are about to dry up. I just did mine a few weeks ago, so I'm good for another 75k or so. I'll switch to 4600s next time around when I have more money.
  13. Oct 19, 2023 at 12:25 PM
    Chrisbr0vvn
    Yep, I've got coils on the front shocks but no top hats. Haven't had the opportunity to start digging into the project yet but watched a number of YouTubes on it. Be curious if I end up having to disconnect much (sway bar links, move upper arm, etc.) probably worth doing a more involved inspection/clean up while I've got stuff apart anyway.
    Island Cruiser likes this.
  14. Oct 19, 2023 at 12:33 PM
    10thMTNgrunt
    10thMTNgrunt This is the way, step inside.
    2013 TRD Sport
    I did the 3rd gen sport upgrade to my 2nd gen and needed a 1/4 spacer to account for taco lean on the driver’s side, I’m fairly confident the same goes for the off road suspension, regardless of the color coding, as my sports were color coded as well but still required the spacer to level the front end out.
