Replacing 4x4 front wheel bearings
Discussion in '2nd Gen. Tacomas (2005-2015)' started by skytower, Jan 19, 2013.
  1. Jan 19, 2013 at 11:34 AM
    skytower
    skytower [OP] Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    An FYI:
    There is a video out there showing how to replace them. I don't know how he got the plates in between the bearing plate and the hub. I had to cut off the 4 retainer bolts to do it. I also had to use a cut off wheel to split the inner race, without cutting into the hub.
    A bearing clamshell splitter would only move it 3/16 before bottoming out.
    The bolts are $3.50 ish each, at the dealer.
