replacing A/C Compressor on '06 Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PaddyBoomBoom, Jul 20, 2010.
  1. Jul 20, 2010 at 1:39 PM
    PaddyBoomBoom
    PaddyBoomBoom [OP] Member
    Paddy
    Always moving
    Arctic Runner
    about to try and replace the compressor on my 2006 taco. Father-in-law says its possible, mechanic says you have to remove the dash to do it. Anyone done this before? Tips? Tricks? or should I just break down and pay to have it done? Thanks in advance guys.
  2. Jul 20, 2010 at 5:30 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    I believe removing the dash is not needed..............
  3. Jul 20, 2010 at 8:10 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    Compressor being on the engine, I would hope the dash doesn't need to be removed, can't see why.
  4. Jul 20, 2010 at 8:22 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    My thought on this is that the mechanic wanted to replace the expansion valve which on some vehicles is located in the evaporator box behind the dash. You need to do more research on the repairs before you try them at home. If your compressor failed internally it could send lots of metal debris into the expansion valve causing it to not operate properly, which is why I think he said you have to remove the dash. a/c repairs are best to be done by a certified mechanic, plus you get a warranty on the repair in case something else is wrong with your system and the tech misdiagnosed it. I might be a little biased on that since I'm an ASE certified HVAC technician.
    Also if you do the repairs at home, you need to properly evacuate the R134-A from your a/c system, otherwise you will be just letting it leak out and polluting the environment. Most likely you need to take to a mechanic and have them evacuate your system for you then replace whatever parts need to be replaced then bring it back to be recharged.
  5. Jul 20, 2010 at 10:48 PM
    Nirvana
    Nirvana Tesla Auto
    Kris
    Morgan Hill, U.S.A
    2006 Off Road 4X4
    Icon ext. travel 2.5RR in front, Icon ext. travel 2.0RR in rear, BuiltRight uniball UCAs, Wheelers Superbumps, Goodridge steel braided brake lines, BruteForce front plate bumper w/ Warn M9000+synth line, American Auto Horns ACDF, Pelfrey Bussman mount+Sandman bussman fuse block (soon), 255/75R16s on painted stockers...because I'm not paying $800 to rock rash new wheels you scrubs. Shok Industries 2/0 big 4 upgrade and sound deadener.
    Have you taken it to a shop to get the system evacuated before you start working on it? I'm definitely a fan of doing work myself if possible but that's one of the few things you have to hand off to a mechanic. The replacement itself shouldn't be too big of a deal but the evacuating and subsequent recharging of the system should be done by an ASE certified HVAC technician.
  6. Jul 21, 2010 at 7:13 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Make sure you check for leaks before dissassembly, if you can. Once evac'd you can replace the bad parts. The accumulator/dryer needs replaced everytime you open the system. +1 on compressor failure causing shrapnel. You need to flush the entire system without the expansion valve(or orfice tube in the other style system) or the dryer/accumulator in there. If you don't get all the junk out, you will blow a new compressor.
    Check for leaks again before recharging.
    Save yourself a grand in labor and do it yourself. Time consuming, but worth it. Get a repair manual it'll show you the easiest way to get at things.
  7. Jul 21, 2010 at 1:20 PM
    Hard Taco2
    Hard Taco2 Active Member
    British Columbia
    06 TDR Off Road
    Why do you have to replace the accumulator/dryer if the problem is a shot bearing on the compressor? Not being a smart arse, just wondering, as the people replacing my compressor did not mention this.
  8. Jul 21, 2010 at 1:28 PM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    When you open up the system, it lets moisture in. The accum/dryer can only absorb about a teaspoon or so of moisture. That moisture cannot be removed by putting a vacuum on the system. It has to be baked out of the dessicant in the dryer. Moisture freezes and blocks the expansion valve/orfice tube.
    If you don't replace it, you're rolling the dice.
  9. Jul 23, 2010 at 7:15 AM
    PaddyBoomBoom
    Paddy
    Always moving
    Arctic Runner
    alrighty, system evacuated, accum/dryer replaced, compressor unbolted (pain btw). It was like preforming open heart surgery on an elephant, upside down, while it stands on top of you. The problem now is trying to get the damn thing out of there. I'm lazy and don't want to remove any more parts to get the compressor out, anyone know of an easy way to get that thing out?
  10. Jul 23, 2010 at 7:20 AM
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    Dryer should be the last thing to go in, right before you button it up. Open to atmosphere=air dryer:(
  11. Jul 23, 2010 at 9:10 AM
    PaddyBoomBoom
    Paddy
    Always moving
    Arctic Runner
    sorry forgot to say that all hardlines are sealed shut to prevent moisture and its a V6 so room in cramped in there.
  12. Jul 10, 2011 at 2:39 PM
    G17GUY
    G17GUY Well-Known Member
    Modesto Ca
    tacoma
    spining hub caps chrome stick-on trim new car smell air freshiner stering wheel suicide knob nut sack on hitch back window curtain
