Replacing A/C Condenser Myself
Discussion in 'Technical Chat' started by Nightops, Aug 22, 2013.
  1. Aug 22, 2013 at 6:05 PM
    Nightops
    Nightops [OP] Member
    Nashua, NH
    K&N 63 short ram, Magnaflow Exhaust, OME lift with Dakars.
    Hi all,
    I have an 03' Xtra cab. V6 5 speed. I had my oil changed at a Valvoline shop and also did an A/C service. A month went by and my A/C stopped pushing out cold air. I found out that I lost all fluid because the bottom of my condenser split. I went back to the shop and they said that they will refill the refrigerant after I replace the condenser free of charge.
    I'm technically inclined and a DIY'er. I'm wondering if this is something that I can replace with ease or If I should have it done. Also, any recommendations whether if I should go OEM or aftermarket when buying parts. I've been quoted over $200 for an OEM condenser from multiple part shops. Online I just found a Denso for about $140. I'm not concerned about the fluid because I'm pretty sure the whole system is bone dry. Any input is appreciated. Thanks.
  2. Aug 22, 2013 at 7:47 PM
    BamaToy1997
    Bill
    Navarre, FL
    It is not a difficult job at all if the system is empty, and you have a place that will vacuum and charge it for you. In all honesty if you feel comfortable replacing the radiator, then the Condenser is not much different.
