Replacing A/C pulley
Discussion in '1st Gen. Tacomas (1995-2004)' started by jgolemon003, Mar 14, 2015.
  1. May 21, 2018 at 2:16 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yeah, I was looking at this
    https://www.toyotamcdonoughparts.com/oem-parts/toyota-clutch-assembly-8841035340/?c=Zz1odmFjJnM9Y29uZGVuc2VyLWNvbXByZXNzb3ItYW5kLWxpbmVzJmk9ODQxNDA5NTUmcj1sYXllcl8xMiZhPXRveW90YSZvPXRhY29tYSZ5PTIwMDQmdD1iYXNlJmU9My00bC12Ni1nYXM=
    Wondering how hard it would be to install. I'm guessing easier than just replacing the bearing as you did?
    Will have to try to look through my FSM pdf when I get home.
    GQ7227 likes this.
  2. May 21, 2018 at 2:28 PM
    wolverine8
    wolverine8 Well-Known Member
    MV
    06 Sport 4X4 - SR5
    Stock
    Oh yea, it should be a bit easier to just swap those 2 front parts out...no bearing pressing involved....you only need the front 2 pieces of that diagram - the cover plate and the mag. clutch, the 3rd piece with the hoses...should not need to be replaced...if you do remove that 3rd plate with hoses, that would be a complete system drain and refill....
  3. May 21, 2018 at 2:30 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Gotcha. I figured as much. If that's necessary I'd just fork over the money to get the whole compressor replaced. But I'm gonna try to just replace the clutch myself.
    wolverine8[QUOTED] likes this.
  4. May 21, 2018 at 2:33 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    well now that I'm looking, no so sure the illustration or prices are accurate.. different diagram on this page:
    https://www.toyotamcdonoughparts.co...ressor-and-lines-scat/?part_number=8841035340
    The weird thing is the entire clutch assembly is $158, if I just buy the two parts you said to get it would cost $212 just for the rotor portion. I'll have to call the parts dept and see what's up.
  5. May 22, 2018 at 9:02 AM
    TacoBunny
    TacoBunny Well-Known Member
    AZ
    1997 5 Lug 5VZ
    You guys seem to know what youre talking about regarding the compressors, My compressor is shredding ac belts like nobody's business. I just replaced the idler pulley and it spins freely. Would a bad bearing cause this? I dont have any of the squeaking other members are describing.
    GQ7227 likes this.
  6. May 22, 2018 at 7:59 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    could be the clutch bearing or your compressor seized... hope it's not the latter.
    GQ7227 and TacoBunny[QUOTED] like this.
  7. Oct 14, 2018 at 6:38 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    The bearing on my Ac compressor has taken a shit. Clutch is fine, bearing is whirring away.
    Here’s my question....I can’t seem to find a compressor clutch assembly. I’d like to replace the bearing. Did you need to have the compressor off to replace the bearing? Or is the bearing attached to the clutch, and you can replace the bearing with the removed clutch assembly on the bench?
    GQ7227 likes this.
  8. Oct 14, 2018 at 7:55 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Yes you can. Someone has shared the part on here before. Just search clutch AC bearing and you'll find some posts in relevant threads. Just have to tap out the old and tap in the new.
  9. Oct 14, 2018 at 8:37 PM
    Spoonman
    Jamie
    Alberta
    Awesome. Thank you. It’s in this thread somewhere I think.
  10. May 8, 2019 at 2:10 PM
    Porthos33
    Porthos33 Active Member
    Eric
    TN
    2002 Toyota tacoma prerunner ext cab
    brush guard, 3" coil spacer lift with add a leaf in rear, Are camper top, k&n air intake, 2 hella ff1000 driving lights
    So I hate to resurrect this.....but I have an 02 tacoma and I'm not sure how to keep the clutch still to get the bolt off. I got the tool to hold it but mine dose not have the three holes to attach the tool. If I put the belt on would that hold it tight enough? Any suggestions? Thanks
    GQ7227 likes this.
  11. May 9, 2019 at 7:31 AM
    TacoBunny
    AZ
    1997 5 Lug 5VZ
    Sorry i never replied, it was my Idler pulley, easy to replace
    GQ7227 likes this.
  12. May 11, 2019 at 8:20 AM
    Porthos33
    Eric
    TN
    My oil filter wrench ended up working to hold it still
  13. Jun 3, 2019 at 2:27 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
