Replacing a transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by IslandYotaBoy, Dec 5, 2016.
  1. Dec 5, 2016 at 6:44 PM
    IslandYotaBoy
    IslandYotaBoy [OP] Active Member
    Nick
    NorCal
    2005 Tacoma v6 trd and 98 tacoma 2.3l 4 cylinder
    So I have 150,000 miles on my 2005 Tacoma. Noticed that going into third gear grinds quite a bit talked to my mechanic about it, and he said that the synchro is bad on it and it needs to get replaced.
    question is: is replacing a manual transmission and clutch doable. with some mechanical know how and the gumption to do it?
  2. Dec 5, 2016 at 7:13 PM
    5amtaco93
    5amtaco93 Well-Known Member
    Sam
    South Bend, WA
    '11 base 4x4 5 speed
    I can't remember
    I replaced the throw out bearing in my 2011 Tacoma in an afternoon. Had a buddy help me. Just need a floor jack and a basic tool set. And maybe a case of beer
  3. Dec 5, 2016 at 7:45 PM
    JTD408
    JTD408 Well-Known Member
    Santa Clara
    2015 DCSB 4x4 TRD Sport
    Icon stage 3 SCS stealth 8's Clazzio sear covers Weathertech floor loners Redline hood struts
    I too replaced the throw out bearing on my 2005 Tacoma. The bearing went bad and I had to replace the new throw out with another new throw out. The odds of that happening are almost nill. Pulling the tranny with a buddy wasn't too bad. Definitely need two guys to handle removing and reinstalling. Pretty simple job though!
  4. Dec 6, 2016 at 5:32 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    It more than likely is just a worn syncro as your mechanic said. I think you misunderstood him however. The Syncro can be replaced without replacing the entire transmission.
    Just have a transmission shop replace the syncros.
    You do not need a new transmission.
  5. Dec 6, 2016 at 7:37 AM
    IslandYotaBoy
    Nick
    NorCal
    Ok, Is that much cheaper? Because My mechanic said itd be upwards of $3000 to do a tranny and a clutch...
  6. Dec 6, 2016 at 5:58 PM
    JTD408
    Santa Clara
    Depending on cost and whether or not if you plan to keep the truck for awhile, it might be better to find a wrecked truck with low miles with the the same tranny and replace it.
    shakerhood likes this.
  7. Dec 8, 2016 at 10:23 AM
    IslandYotaBoy
    Nick
    NorCal
    tough to find but ill look into it. I wish it was easy to replace the syncrho rings
  8. Dec 8, 2016 at 1:22 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    It is for a transmission repair shop. And probably cheaper too.
  9. Dec 8, 2016 at 1:48 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    There is a thread on XRU where a guy rebuilt his, due to bad syncros. Should I look for it?
  10. Dec 8, 2016 at 2:38 PM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Rent/borrow a transmission jack. Do the R/R yourself, and DIY the clutch. Have a good transmission shop perform the rebuild. You'll save $$.
    Rebuilding a manual transmission is actually pretty easy but requires more specialized tools than the average home shop is equipped with - pullers, hydraulic press, micrometers, etc. Better to just farm out the rebuild and save on the removal/install.
  11. Dec 8, 2016 at 3:37 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    It really comes down to how confident you are in your abilities. If this is your first go at doing something mechanical you shouldn't try it unless you have someone with experience helping you.
  12. Dec 11, 2016 at 2:03 PM
    IslandYotaBoy
    Nick
    NorCal
    I understand, yeah I could have up to a week at the beginning of January, but I may just wait till I save up money before having it serviced.
    Ruggybuggy likes this.
  13. Dec 12, 2016 at 3:34 PM
    IslandYotaBoy
    Nick
    NorCal
    Ive done some mechanical stuff, basic stuff in the past. Im thinking about it... Id have to get a transmission jack, i have an air compressor probably would get an impact ratchet, amongst other tools id need...... Thinkin...
  14. Dec 12, 2016 at 3:36 PM
    IslandYotaBoy
    Nick
    NorCal
    I could.. I have 5 days or so I could be working on it after christmas lol, just dont want to get over my head and be SOL!
  15. Dec 13, 2016 at 4:39 AM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    Do you really need 3rd gear? You have 5 other gears that work plus reverse. Our transmissions have twice the amount of forward gears as the older vehicles so you can lose 2 more before you have to start to worry.
  16. Dec 13, 2016 at 8:27 AM
    IslandYotaBoy
    Nick
    NorCal
    I want 3rd gear, I get kind of obsessive about stuff like this.. talked to my old high school auto shop teacher lol he thinks I could do the install. Anyways I'm gonna see how much synchro replacements cost At a transmission shop in Oakland n see what they charge. He suggested doing the clutch, master cylinder, rear main seal, resurfaced flywheel or new flywheel as well
