Replacing ball joint--UCA
Discussion in 'Suspension' started by nighthawk87, Jun 28, 2010.
  1. Jun 28, 2010 at 10:24 AM
    nighthawk87
    nighthawk87 [OP] Well-Known Member
    Chris or Someone:
    I have a constant popping/squeeking coming from my drivers front suspension after installing coilovers. I think I may have damaged my ball joint when popping the spindle off the UCA.
    On the drivers side I hit the bottom bolt with a sledgehammer to pop it off...on the passenger I hit the side of the spindle and it popped off after a few taps.
    I am thinking my ball joint is bad.....
    Is there a way to confirm this???? If it is, how do I replace it and it is it more economical to just go with new UCAs instead since I'll be doing that eventually?
    Help!
  2. Jun 28, 2010 at 10:39 AM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Make me an offer and I'll sell you the UCA's I took of my 09 Tacoma.
    They were only used for approximately 8 months / 13,000 miles.
  3. Jun 28, 2010 at 10:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    See if you can pull up on the suspected bad ball joint. Also, Grab the top of the tire, and try to move it in and out (when on the ground). If you feel any play, even a little bit, the balll joint is bad.
  4. Jun 28, 2010 at 11:02 AM
    nighthawk87
    My buddy mentioned that there is a plastic lining inside that I may have shattered when hitting the bottom bolt to break it loose.
    does that come with the ball joint or the uca?
  5. Jun 28, 2010 at 11:21 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I dont know about a plastic lining.....
