Replacing belt and tension pulley every few months
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Joe_Gaston, Dec 17, 2023.
  1. Dec 17, 2023 at 11:16 AM
    Joe_Gaston
    Joe_Gaston [OP] Member
    2006 Tacoma
    None
    Hello,
    I'm looking for any suggestions on how to diagnose what I believe is deeper issue outside of my serpentine belt and tensioner pulley on my 06 Tacoma w/ 310,000 miles on it. I'll start out with a little history:
    Feb23 - Belts begins squeaking along with noises from pulley. After a few weeks belt gets thrown and tensioner pulley is broken off and laying in my front skid plate. Replace pulley and belt
    July23 - While on a road trip belt and pulley begin making noise. After a week or so while driving pulley seizes and throws belt off. Replace pulley and belt
    October23 - Belt and pulley begin making noise. A couple weeks later pulley seizes and throws belt off. Replace both.
    Currently, I have no issues. I'm no mechanic, but it seems like maybe something else connected on the belt is either providing friction, inconsistent idling, or uneven pressure across the tensioner pulley. Second, Maybe it is the tensioner itself?
    The truck is old, but mostly runs very smooth. It has a rear main seal leak and has it for about 100,000 miles. I am losing a little oil between changes from this, but am I losing engine pressure they may cause inconsistent RPMs? In the last year, the truck has felt a little "slower" with RPMs through the gears. Could a poorly performing engine be causing this issue?
    Again, I am no expert and try to do my research and can do minor jobs on my truck like replacing these parts. I would appreciate any help or suggestions - even if its to convince me to just go ahead and by that new tacoma Ive been looking at :spending:
    Joe
  2. Dec 17, 2023 at 11:19 AM
    Bishop84
    Bishop84 Well-Known Member
    Do you off road gravel often? I change mine once a year because of all the dust. I've tried every brand, nothing works.
    Joe_Gaston[OP] likes this.
  3. Dec 17, 2023 at 11:21 AM
    Joe_Gaston
    2006 Tacoma
    None
    Hey Bishop, I dont offroad with it much at all, but I do live in southern Arizona and the amount of dust in the environment is significant.
  4. Dec 17, 2023 at 11:28 AM
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    What are details on the engine? 2.7 or 4.0? Might help.
  5. Dec 17, 2023 at 11:38 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Have you replaced the whole tensioner assembly or just the pulley?
  6. Dec 17, 2023 at 11:38 AM
    tak1313
    tak1313 Well-Known Member
    2013 Base 2WD
    What brand belt and tensioner have you been using - and where are you getting them? Although I am NOT an 'everything needs to be OEM' guy, there are inferior brands and sources.
    Jakerou and Joe_Gaston[OP] like this.
  7. Dec 17, 2023 at 11:54 AM
    Joe_Gaston
    2006 Tacoma
    None
    Hey, its the 4.0
    MarX[QUOTED] likes this.
  8. Dec 17, 2023 at 11:55 AM
    Joe_Gaston
    2006 Tacoma
    None
    Hey, Thats what I'm thinking is probably going to be my next step.
    MarX likes this.
  9. Dec 17, 2023 at 11:56 AM
    Joe_Gaston
    2006 Tacoma
    None
    Hey, thanks for your reply. Im not exactly sure on the belt, but the pulley is the original that comes with the tensioner.
    MarX likes this.
  10. Dec 17, 2023 at 12:14 PM
    MarX
    Mark
    NE Kansas
    :thumbsup:
  11. Dec 17, 2023 at 2:47 PM
    Waasheem
    Waasheem
    2007 xrunner
    Like what tak1313 said, your problems could be bad new parts.
    Give this a try. Stand on the side forward of the front tire. Look straight line of sight at the pulleys. Just inside of the outer lip where the outside edge of the belt rides. All of the pulleys should be very close to perfectly aligned.
    Something else to look at. Every pulley the belt touches should spin without wobble. A wobbly pulley would cause a rapid loose tight belt and probably a noticeable bounce.
    I’ve seen plastic get wrapped in a pulley, melt and fuse to the pulley and cause bouncing.
    tak1313 and GilbertOz like this.
  12. Dec 17, 2023 at 3:06 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    In February was that the original tensioner pulley and belt that went bad? Are getting oe parts from the dealer? Or are they parts house parts?
  13. Dec 17, 2023 at 4:56 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    The same pulley is failing? You said it was the tensioner……how are the idler and water pump.
  14. Dec 17, 2023 at 7:12 PM
    TacoTuesday1
    SD CA
    -is there proper belt tension
    -is every pulley good
    -are you using high quality parts
    -is the belt clean (not being leaked on) and kept rotating the same way by marking it if removed
  15. Dec 17, 2023 at 7:21 PM
    joba27n
    joba27n YotaWerx Authorized tuner
    Nolan
    Alberta
    2021 Gray TRD Sport Tacoma MT
    YotaWerx Stage 1, Bumper light bar, Hood wrap, Roadmaster Active Suspension, Durobumps.
    Look for a rust cloud on the face of all your pulleys, with the belt off try to spin everything by hand and/or with the engine running look from the side of the engine at the belt tracks straight around everything and nothing sticks out. If you have a manual have someone depress the clutch while looking to see if the crank walks a bit.
    Have you done any other work under the hood lately? If your fan clutch super wobble or pretty solid?
    my 96 f150 would throw a belt at high rpms. Someone at some point changed the power steering pump and didn't fully seat the pulley to the pump so that threw of the belt alignment and would eat pulleys and throw belts until I sorted out the power steering pump
  16. Dec 18, 2023 at 6:50 AM
    tak1313
    2013 Base 2WD
    This is confusing. In your original post, you indicated you replaced the pulley on Feb 23, July 23, and October 23. So the pulley can't be the "original that comes with the tensioner," or have you replaced the tensioner (with pulley) 3 times?
    If you replaced JUST the pulley 3 times, what brand did you replace them with and where did you get them? Was there a spacer in the original that perhaps you did not use when replacing? If there was a spacer, without a proper spacer, there will be undue pressure on the inner race of the bearing when the pulley is torqued down.
    joba27n likes this.
  17. Dec 18, 2023 at 10:41 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You couldn't have replaced the tensioner pulley with oem pulley. Last I checked, Toyota does not sell the tensioner pulley separately. They only sell it with the tensioner assembly.
    On Feb, when tensioner pulley first broke off, was it the bolt that broke? It’s reverse-threaded - where did you get a new bolt?
