Replacing brake pads-new hardware?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by efiles123, Jul 7, 2023.
  1. Jul 7, 2023 at 11:21 PM
    efiles123
    efiles123 [OP] Active Member
    I'm getting ready to replace the front brake pads and have my rotors turned on my 2015 prerunner. I already have the oem pads (04465-AZ200), that I'm almost positive are the correct ones. Please let me know otherwise. Anyway, I noticed the pads do not come with any fresh hardware, clips, pins, ect. I've looked around for an answer and noticed people say to re-use the shims but what about the clips, springs, and pins?
  2. Jul 8, 2023 at 3:19 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    Sometimes I reuse stuff and other times I install new parts. It depends on the condition of the parts. I did front brakes on my truck months ago. I needed new front calipers so I replaced everything, (shims, pins, clips, and W-springs).
  3. Jul 8, 2023 at 4:19 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    Unless you are in the rust belt the hardware should be ok to use again. Some of those hardware kits sold in stores are garbage.
  4. Jul 8, 2023 at 9:08 AM
    efiles123
    Thanks for the replies guys! I'm in CA so not much rust out here. I'll plan on reusing the old stuff.
    In case I end up having to replace hardware will aftermarket work with oem pads? It's so much trouble finding this stuff oem unless someone has the part numbers.
  5. Jul 8, 2023 at 11:47 AM
    tacobp
    tacobp Well-Known Member
    Bob
    North Carolina
    09 Tacoma, 2.7 automatic
    Installed a Pop n Lock,,That's it !..Bone stock
    OEM hardware is best with OEM pads. Your dealership should be able to match them up.
  6. Jul 8, 2023 at 1:09 PM
    pahaf
    pahaf Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    just reuse them.
    what i do for the pins.....just clean them with a wire brush. spray brake clean. apply break grease...send it.
    also will hit the caliper and the brake rotor hat with the same wheel.
    all the other clips should be fine to reuse for a long time.
  7. Jul 8, 2023 at 5:36 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Just clean the pins and the channel shims (the stainless steel liners the pads rest in), and install the new pads. I've replaced the hardware in the past but often, the OEM units I removed were heavier/thicker than the replacement parts. I have some small, toothbrush sized wire brushes I use for those channel liners.
    They should clean up ok, especially on a California truck.
