Replacing brakes w/o removing brake line.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BeeRadd, Jun 6, 2012.
  1. Sep 16, 2012 at 12:47 PM
    #61
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Not a bad job.. My husband and I tackled the job on Friday. We've done plenty of brakes before but never with pistons on both sides. Got the rotors turned locally for $50 (original rotors) and bought OEM pads.
    Strange anti-squeal plates. Two plates sitting on top each other. One plate had slots in it with some sort of dimpled surface on it.
    I almost lost one of the damn clips on the pins.
    I accidentally ordered two sets of pads...so if anyone is interested, I can get you a part number and price. These are OEM pads.
    New brake job fixed a 'clunk' I was getting when applying the brakes.
    The old brakes had about 3/16" pad left and 51,000 miles on them.
  2. Sep 16, 2012 at 2:17 PM
    #62
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    If you remove the clip that holds the flexible line on there is a slot in the bracket that you can slide the metal line through and not have to bend it.
  3. Apr 27, 2015 at 4:31 PM
    #63
    Waldo1dk
    Waldo1dk Active Member
    William
    NE Florida (Baja Georgia)
    2006 DC TRD Sport
    K&N and 33's
    So old thread, but I'll throw it out there. My Rotors were warped, (175,000 miles and like a bucking Bronco in a Hard Stop) so I went with some slotted and drilled rotors as I have an ungodly 1.5 hour commute each day and wanted some cooling. (I know dirt and chit will build up but my boy has his own now some traffic is more the norm). I changed both sides of course and now I have an annoying rattle that goes away when I apply some Brake Pedal, worried that it's wearing the pins, the Calipers not Hot, so not worried about a lock up at this point. Any ideas?
  4. May 1, 2015 at 6:59 AM
    #64
    Waldo1dk
    William
    2006 DC TRD Sport
    K&N and 33's
    I went and got OEM Anti Rattle Springs and then put the aftermarket one on the bottom and the rattle is gone.
  5. May 1, 2015 at 10:45 AM
    #65
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I would open the bleeder before compressing the caliber. I never worried about until I did the brakes on my Sporttrac. I use to just loosen the cap on the master cyl.. Now maybe the caliber was weak anyway but while compressing it sprung a leak.
  6. May 1, 2015 at 5:00 PM
    #66
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    Thanks for the write up.
