Replacing bucket seats w/ seats with comfortable buckets.
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, May 28, 2016.
  1. May 28, 2016 at 2:01 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    The buckets in my 02 sr5 4 door are uncomfortable garbage!
    Im looking into replacing them with big padded cadillac or mercedes bucket seats.
    This is my "DD" and I routinely drive 250 Plus miles in this truck. The seats are so uncomfortable that anything beyond 100 mi makes me want to drive it into a river and call a cab.
    Has anyone done this sucessfuly?
    Im also concerned they will be too wide to fit in the truck.
    Im not completely hung on Cadillac or Mercedes, they just seem to be a good choice.
    Im open for suggestion if anyone knows of a better choice.
  2. May 28, 2016 at 9:54 PM
    mikesdoublecab
    mikesdoublecab LT Chase Truck
    Mohawk Mike
    Glendale, CA
    01 Tacoma DoubleCab V6 Prerunner
    Engage Offroad long travel front and rear with some fat tires.
    i can't imagine that the luxury seats would fit width wise in there... have you taken measurements yet?
  3. May 29, 2016 at 9:50 AM
    bodhi armor
    Joshua
    East TX
    Not yet, there are a few you pull it scrapyards here in town that i plan on visiting.
    I dont expect the larger luxury seats to fit very well without some serious "shoehorning" im hoping to find a mid size suv with tall skinny seats.
    Im also going to raise the seat position about 1.5" front and back for more of a " full size truck" feel.
  4. May 29, 2016 at 9:56 AM
    bodhi armor
    Joshua
    East TX
    My other concern is seat adjustability.
    My original seats are manual adjust as opposed to more modern seats which are electronically adjusted.
    If anyone knows anything about transplanting electronically controled seats i would truly appreciate any advice.
  5. May 29, 2016 at 12:17 PM
    kgw
    kgw Well-Known Member
    kgw
    SoCal
    99 PreRunner
    140 amp alternator, Big 3 upgrade, Ultimate Headlight Mod, Trans Cooler
    Try to get all the wiring harnesses with connectors intact...
  6. May 29, 2016 at 2:25 PM
    bodhi armor
    Joshua
    East TX
    Ill most definitely get all the wiring and fittings that come with the seat.
    Im hoping to find electricaly controlled seats that only require a power source to operate and doesnt require communication with the cars computer system.
    Any ideas on how to figure out which manufacturers use that type of system?
  7. May 29, 2016 at 3:45 PM
    kgw
    kgw
    SoCal
    99 PreRunner
    No "memory" system for seat position, or any airbags in the seat. Heated seats are awesome, but without a temp regulator could get tricky! ;)
  8. May 29, 2016 at 7:32 PM
    Madjik_Man
    Colorado Front Range
    Just need to run a positive lead with an inline fuse and ground to it. The fuse I using is a 10amp.
    My driver's seat is power adjustable and I tapped into the distributor blocks under the seat for my amp set up.
  9. May 29, 2016 at 8:19 PM
    bodhi armor
    Joshua
    East TX
    That
    That is tremendous news!!
    Ive been looking on ebay and have found a pair of reeeally nice Infinity leather buckets for about 800$. If i can find some at a you pull it I think i can probably get them for about half that.
    What manufacturers do yall think make the comfortable seats?
    Infinity, Mercedes, Lexus, Bmw, Range Rover, Audi, Cadillac, etc??
    Ive never driven a luxury sedan or suv, ive always owned trucks or classic muscle cars.
  10. May 29, 2016 at 8:26 PM
    Madjik_Man
    It's a matter of what will fit width wise (as you know). In terms of comfort that's a question for your tuchus and lower back :)
    I have a feeling a lot of those high end maufactures you mention will be more involved than a positive and ground wire.
    The Subaru seats I put in my truck literally just had a red and black wire coming out from the bottom of the seat.
  11. May 29, 2016 at 8:33 PM
    bodhi armor
    Joshua
    East TX
    I
    Positional memory isnt a concern, neither is heated seating. I live in TX so i wont ever use the heat feature, but the cooling/ air flow feature would be AMAZING.
    If, as you say, the heating feature could cause complications i will likely disconnect the heating element entirely.
    As far as in seat airbags go, I expect they will be ok if disconnected from electrical current.
    Does anyone see a potential problem with that, or are my assumptions correct?
    The last thing I want is to be driving along jammin on some Zepplin then get knocked out by an unexpected air bag discharge.
  12. May 29, 2016 at 8:38 PM
    austin21
    austin21 Well-Known Member
    Austin
    Bend, Oregon
    2014 Super White Tacoma SR
    Cut springs
    :headbang:image.jpg Get these :taco:
  13. May 29, 2016 at 8:39 PM
    bodhi armor
    Joshua
    East TX
    How do you like the subaru seats? Scale of 1-10
  14. May 29, 2016 at 8:45 PM
    bodhi armor
    Joshua
    East TX
    Do you have any experience with those seats?
    It looks like they would be a little movement restrictive and difficult to get in and out of due to the high sides.
  15. May 29, 2016 at 9:30 PM
    Madjik_Man
    I give it a solid 8. Could be a hit softer for my liking but they're Subby seats out of an XT. So they're meant to be firm.
    Compared to stock? So much better.
  16. May 30, 2016 at 12:05 PM
    austin21
    Austin
    Bend, Oregon
    Cut springs
    I havent had them i just want them haha
  17. May 30, 2016 at 6:24 PM
    bodhi armor
    Joshua
    East TX
    8/10 you say? Thats pretty good.
    My next day off is going to be spent at a massive local "you pull it" here in town. According to a guy i work with, they have everything from cheap ass beaters to high end luxury vehicles.
    I really hope i can find a Porsche Cayanne, i drove one yesterday and the seat made me feel like a KING! I felt like i was getting an ass and back massage!
    If i buy a pair of those I may just sell my house and live in the truck!
  18. May 31, 2016 at 6:56 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    I had some Wrx seats in. I loved them. Probably a 9/10 the lumber didn't fit me quite right
  19. May 31, 2016 at 7:05 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    You don't want those seats, they are extremely narrow. The Corbeau LG1 is far more comfortable and a normal width. Look up the actual specs of those seats and bust out a tape measure and you will see what I mean.
  20. May 31, 2016 at 7:06 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Can't wait to acquire those, Jake! I PM'd you, btw...
