Replacing clutch and manual transmission -- what else?
Discussion in '1st Gen. Tacomas (1995-2004)' started by pontoon, Feb 9, 2017.
  1. Feb 9, 2017 at 7:31 PM
    pontoon
    pontoon [OP] Well-Known Member
    2000 Tacoma SR5 TRD V6 3.4 5MT
    I've got a rebuilt transmission and a new clutch/flywheel that I'm going to have installed. Is there anything else that I should replace while everything is taken apart? I'm particularly interested in any gaskets or seals that might be easily replaceable so that I can avoid oil leaks down the road. Are there any seals/gaskets between the transfer case and transmission? It's a 2000 4x4 SR5 V6 TRD. R150F transmission.
  2. Feb 9, 2017 at 7:37 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    rear main seal, motor mounts, tranny mounts, u-joints, carrier bearing, x-fer case input/output shaft seals. really isn't anything else except the shift ball bushings. rebuilt tranny should come prefilled or at least with new crush washers.
  3. Feb 9, 2017 at 10:39 PM
    pontoon
    Thanks!
  4. Feb 9, 2017 at 11:24 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Yip id definitely do the rear main also as codeseven mentioned!
