Replacing clutch fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Jul 6, 2015.
  1. Jul 6, 2015 at 3:02 AM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    this is the only fluid I haven't changed in my truck. How is it done? The brake system has fresh fluid in it as of 10k miles ago.
  2. Jul 6, 2015 at 6:17 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Pop the bleeder open on the slave cylinder and bleed it out like the brake system using either your foot, gravity, or a power bleeder.
  3. Jul 6, 2015 at 12:31 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Okay, is the slave cylinder the small reservoir next to the brake reservoir?
  4. Jul 6, 2015 at 1:09 PM
    slander
    Hickory, NC
    Slave cylender is sticking out of the driver side of the trans with a boot touching the shift fork. Therese an "S" shaped hardline going to it and you will see a bleeder screw on it like the brake caliper has.
  5. Apr 13, 2017 at 11:17 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Thanks, and sorry for the eternally late reply. Gonna get to it this spring.
    One more thing, where do I add the new fluid as the old stuff drains out?
  6. Apr 13, 2017 at 11:22 AM
    Clearwater Bill
    Billy
    Largo Florida
    In the clutch master. You described it above as the small res next to the brake master res.
    Clutches are typically a bit tricker to bleed than brakes. If you don't have a bleeder, the two person method is your best shot, with an experienced person working the slave and calling the shots.
  7. Apr 13, 2017 at 11:23 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Is a gravity bleed a possibility in this situation? Or not advised?
  8. Apr 13, 2017 at 11:26 AM
    Clearwater Bill
    Billy
    Largo Florida
    I've never done it on a Tacoma, but I have, successfully, on other marquees. The question is will it really start draining on it's own. Some seem to require the pumping to get things moving.
    OP, just like on brakes, be sure the master doesn't get empty, or you'll have to start over by bleeding the master.
    And in case you are wondering, there is no product called 'clutch fluid'. It's brake fluid that gets used. I've always seen the same DOT spec as the brakes called for on a given vehicle.
  9. Apr 13, 2017 at 11:27 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Gotcha. Thanks!!
