Replacing CV Axle
Discussion in '1st Gen. Tacomas (1995-2004)' started by Peediz, Jul 28, 2015.
  1. Jul 31, 2015 at 3:54 AM
    travelfeet
    travelfeet Well-Known Member
    Andrew
    Troy, NY
    02 xtra 4x4 v6
    Peediz, do you know what caused the hole in the boot? I just discovered my driver side outer boot has a hole in the top of one of the pleats. Looks like something was rubbing on it and wore through, but its only about an inch long instead of all the way around as would be expected. I have never been off road so I can't guess how this happened. I'd hate to replace (and I am i your position, new axle or just replace the boot?) and have the same thing happen again.
    The ads I have seen for half shafts often say "left or right" I haven't checked part numbers, but that's a fair indication that they are the same on both sides.
  2. Jul 31, 2015 at 6:37 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    The axles are not side specific.
  3. Jul 31, 2015 at 8:17 AM
    Peediz
    Peediz [OP] Active Member
    Long Island
    03 TRD Off Road 3.4 V6
    The hole in the boot is my own fault. When changing out the shocks I had to use heat on the seized bottom bolt to get it out. It ended up melting a piece of the boot. Nothing horrible but enough of a hole to allow grease to spit out.
  4. Jul 31, 2015 at 9:47 AM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Changing an outer boot adds maybe 10 minutes to an inner boot change. The inner boot job is 95% of the work and must be done in order to install an outer. Nothing tricky about an outer, just 2 clamps and clean the old lube.
    All aftermarket "new" CV's are Chinese knock offs with questionable or non existent quality control, less than OEM range of motion, strength and life.
    For any kind of off road use a really common practice is to pick up a used/rebuilt OEM and re-boot the leaky one as a trail spare.
    ThunderOne likes this.
  5. Jul 31, 2015 at 6:24 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    All you have to do is remove the inner boot and tripod and then you can do the outer boot easily.
  6. Jul 31, 2015 at 6:33 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    No difference between left or right
  7. Aug 4, 2015 at 10:23 AM
    Peediz
    Long Island
    Got the new CV installed. Now there's a popping noise coming from the front. It's happening on some turns as well as uneven road bumps. Any idea what could be causing this?
    I know my sway bar bushings are fairly shot, but if it is that, how does that cause it to "pop"?
    I'm supposed to be taking a road trip in a couple days but now I'm hesitant about taking the truck.
  8. Aug 4, 2015 at 10:25 AM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    Did you make sure to seat and pop the cv axle back into place ?
  9. Aug 4, 2015 at 10:28 AM
    Peediz
    Long Island
    It was done at a 4x4 shop. I'm trusting they knew what they were doing (hopefully).
  10. Aug 4, 2015 at 10:51 AM
    LikeABoss4x4
    LikeABoss4x4 Well-Known Member Vendor
    Sarah
    So Cal
    I'd take it back to them ASAP if it is popping... likely not installed correctly.
    Also, for those just needing to replace the boot, these are a great option, especially for lifted trucks:
    The "fins" are more rounded and don't rub together when at an angle like the stock boots. You can also get a hose clamp to make the install easier. The clamps have rounded sides so they will not cut into the boot.
    alphabravo likes this.
  11. Aug 4, 2015 at 9:51 PM
    Peediz
    Long Island
    Popping noise fixed!! I tightened up the upper nut on the sway bar end link. Problem solved.
    Thanks again for everyone's help.
  12. Aug 5, 2015 at 4:32 AM
    Sundowner
    Sundowner Member
    2002 Tacoma TRD X-cab
    optional rusty everything has been progressively installed over the past 14 years
    why don't you just buy a new set of boots? they're like $9 each. all the work is getting the damn axle out of the truck. it takes about 20 minutes to break down the CV, clean it, check it for wear, and then reassemble with new boots.
  13. Aug 12, 2015 at 12:18 AM
    SmogSUX
    SmogSUX No Money. No Love.
    Sacramento
    96 Tacoma Manual 2.7L 4x4
    Wheelers 5-Pack w/ AAL, ToyTec 1" Shackles, 10" 5125's, 5100's w/ ToyTech Springs, Braided Steel Brake Lines, AFE Filter, BAMF Sliders
    What do you guys think about my situation though:
    I wouldn't mind keeping my OEM axles, but both inner boots have been 100% torn for over 3 years...should I just go Napa at this point?
  14. Aug 12, 2015 at 9:54 AM
    bellassaiw10
    Currituck NC
    I went the Napa route. Hard to beat lifetime replacements. If you wheel hard enough they're gonna break eventually I've been through oem and remans
  15. Aug 12, 2015 at 10:07 AM
    #35
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    I rebooted both of my cvs this summer and they have held up to some pretty rough trails and flex. I've heard from quite a few people on TW that aftermarket axles do not perform as well as OEM. I'd rather stick to factory parts than aftermarket if I can.
    Bought 2 of these kits, one for each axle: http://store.sdhqoffroad.com/oemreplacementcvbootkits.aspx
  16. Apr 9, 2016 at 6:19 PM
    #36
    Blackouts
    Blackouts Well-Known Member
    Las Vegas, NV
    2014 Tacoma TRD Off Road DCSB
    @alee891 How have those boots held up?
  17. Apr 9, 2016 at 8:23 PM
    #37
    alee891
    Austin
    Black Hills
    Tacomaless
    Not bad at all. Only gripe I have is that the rebuild kit doesn't come with clamps for the inner portion of the boot. I'd recommend getting a hose clamp or similar item to keep the boot on.
  18. Apr 9, 2016 at 8:43 PM
    #38
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    As mentioned , no need to chisel anything (if you have too, you've bigger issues) As for axle nut, some CV's com with/some don't , but pretty sure all will come (or should) with retainer (thin castle nut looking thing w/notches for cotter pin) ...
    Most rips are from excess CV angle, it offroading, not as much if not..
    Meh, what do YOU know ?...:p
  19. Apr 9, 2016 at 11:02 PM
    #39
    bellassaiw10
    Currituck NC
    Hey now watch it.
  20. Apr 10, 2016 at 8:56 AM
    #40
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I have NAPA axles on both sides of my 02. No tears or issues. Seems like NAPA axles (new, not reman'd) are of pretty good quality.
