replacing dome light/tag light/reverse lights with LEDs... need help on which models
Discussion in 'Lighting' started by beef TACO no rice, Jul 28, 2010.
  1. Jul 28, 2010 at 4:44 AM
    beef TACO no rice
    beef TACO no rice [OP] Well-Known Member
    Orlando, FL
    07 taco single cab
    hey guys.. i know theres like 136357234 of you that have done this, and im looking on superbrightleds.com, and crossreferencing the bulb partnumbers, but there are so many available models in that same part number...
    is there anyone that can tell me what ones to go with? id like to get the brightest (bigest/most leds on each bulb) that i can fit in the bulb housing..
    thanks guys,
    -dave
  2. Jul 28, 2010 at 2:49 PM
    CRfofiddyF
    CRfofiddyF Well-Known Member
    FL
    23 TRD OR 4x4
    Dome - > High Power 6-LED Festoon bulb Cool White - 7000K 42mm 4210-xHP6
    Map -> 921-x12 Wedge Base LED bulb Cool White 921-CW12
    License Plate -> WLED-x5 LED Wide Angle LED bulb Cool White WLED-CW5
    you can also use the search function :rimshot:
  3. Jul 28, 2010 at 6:57 PM
    rb11701
    rb11701 Oh yeah!
    Rob
    '09 Silver Streak TRD Off-Road
    Rear Suspension TSB, DTRL Mod, aFe Pro-Dry S,USA Spec PA15-TOY iPod Adapter, Dynolock Tailgate Lock, UltraGauge OBDII Scanner, CoverKing Neoprene Seat Covers
    I put Wide angles in my map. I also went with 4410x9 festoon in cool white in my dome. Matched better to the WLED-CW5's in the map. Went with 3 red WLED-R5's for the third brake light.
  4. Dec 14, 2013 at 4:35 AM
    crusader1
    crusader1 Well-Known Member
    Al
    SC Upstate
    06 PreRunner TRD#1/'73 Datsun 240Z Orig. Ownr
    None yet...just warmin' up
    I just installed Oznium's (http://www.oznium.com/thin-led-domelight) Ultra Thin Dome Light in 1.5x5", the perfect size for my dome light. I chose the "Cool White" from their long list of whites/colors and it's perfect...the inside of my Tacoma XtraCab is like daylight :). Came with all the adapters, of course, and I discovered with one try, it likes its + and - in order!
    Now, I intend to pursue LEDs for Backup, Center Brake and Maplights...for starters. This is the greatest thing since Swiss Cheese :)
    Also, took the advice of the Thread on Blacked-Out Accessory Panels on the overhead, and am sending my removed board into SiliconMethod.com for resistor installation and a dimmer control.
    What a resource...Tacoma World ROCKS:p:);) Thanks, TW!
  5. Dec 14, 2013 at 4:39 AM
    crusader1
    Al
    SC Upstate
    Where did you find the Map Lights? I used Oznium for the Dome, and it's awesome!
    Thanks.
