Replacing entire exhaust system?
Discussion in '1st Gen. Tacomas (1995-2004)' started by yurtdweller, Jul 13, 2018.
  1. Jul 13, 2018 at 10:11 AM
    yurtdweller
    yurtdweller [OP] Well-Known Member
    2003 Toyota Tacoma 2.7l
    Hey friends,
    My Taco had its first trip to a mechanic, since I've been playing shadetree mechanic on it, and once again I have a bad cat converter. He says my entire exhaust system is shot from rust, so I should just replace the whole thing. He says that I should go with OEM, because Toyota tolerances on throwing these codes are so tight, so I should not do aftermarket.
    Has anyone replaced their entire exhaust system before - from the header all the way down to the tailpipe tips? Do I need a welder, or is it all bolt on if it's brand new, OEM?
    Thanks
    Black97v6MT likes this.
  2. Jul 13, 2018 at 10:16 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Magmaflow makes cats
    @Flowmaster Exhaust is a vender here and they also make cats, im sure they will have more info on this.
    But you can get exhust pipe and use clamps to hold it all together. Its not perfect that way but it will last long enough to goto a shop and have them weld it up.
    But a good exhust shop should be able to bend you up a oem like exhust no problem for fairly cheap.
  3. Jul 13, 2018 at 10:17 AM
    yurtdweller
    My question is - if I replace everything from the header down to the tip of the tailpipe, is this a doable DIY job?
  4. Jul 13, 2018 at 10:19 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    He's referring mostly to the cats being inferior to original ones and since you're saying 'once again, bad cat', I guess he's on track.
    Unfortunately, I don't know if a new OEM cat(s) is obtainable.
  5. Jul 13, 2018 at 10:20 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    They sell exhust pipe and even pre bent section so yes with some clamps and ingenuity your can do it by yourself. The clamps work but its cheap enough to goto a shop and have them just weld it all after you install it
  6. Jul 13, 2018 at 10:21 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Also @Flowmaster Exhaust sells bolt in replacement cats that are carb compliant. I would shoot them a pm and see what they say
  7. Jul 13, 2018 at 10:21 AM
    The Driver
    The Driver Trail Runner/Barefoot Beach Runner/Snow Skier
    Raph
    Lakewood (Green Mountain), CO.
    '02 Extra cab 4X4 TRD SR5 3.4
    Aftermarket tranny cooler, 5100 Series Bilsteins, ToyTec Bilstein front coilovers, SPC UCA's, Alcan leafs, Class 3 Hitch, Tundra Front Brakes,
    I'll let you know by Tuesday, as I'll be installing TRD headers and a Magnaflow cat back, with the help of a mechanic friend, this weekend. Alas, he won't do the actual job, he'll be guiding me from start to completition. Or at least that's the plan...
  8. Jul 13, 2018 at 10:22 AM
    JonathanH
    JonathanH Well-Known Member
    Jonathan
    Southern Maryland
    11' DCLB
    This should help if you want to try it yourself. Factory exhaust system pretty much bolts together.
  9. Jul 13, 2018 at 10:47 AM
    yurtdweller
    Thanks, all! Looking forward to fixing this issue hopefully once and for all...
  10. Jul 13, 2018 at 12:01 PM
    Flowmaster Exhaust
    Flowmaster Exhaust Well-Known Member
    Flowmaster
    If you do not live in California or those states that have adopted California's emissions laws I have two Flowmaster Direct-fit Catalytic Converter options for you as well as a Cat-back Exhaust System for your Tacoma. For the front Catalytic Converter, you'll want to take a look at Flowmaster part# 2051040 and for the rear converter part# 2059240. These replacement "cats" will bolt directly to the OEM (or OEM based) exhaust manifold and OEM exhaust system post "cats" or directly to our American Thunder Cat-back System, part# 817519 with no welding of the exhaust system required. I do not offer an OEM exhaust manifold or performance-based replacement header, however, the items we do offer are substantially less in price than OEM, perform identically to their OEM counterpart and are designed off of OEM specifications.
    If you do live in California or a state that has similar emissions laws we offer Universal replacement Catalytic Converters, however, those replacement options are not Direct-fit and will have to be installed by an exhaust professional as part of a "custom" exhaust system. There are a number of variables on the generation of Tacoma that you own so I was not able to get the necessary part numbers, please give us a call at 707-544-4761 for the proper parts recommendation.
    - Jason @ Flowmaster
    Hamer95USA, El Taco Diablo and Weejub like this.
  11. Jul 13, 2018 at 12:31 PM
    Glamisman
    Glamisman Well-Known Member
    You said, bad cat again... is this the second time you are replacing the same convertor, if so, why? If you are being told that you need a new cat because the "computer" told you I would do a little more digging. If you are burning oil that will kill a cat pretty quick. If there is/are perforations in the exhaust upstream of the cat(s) that too will be a false positive for a bad cat(s).
    Black97v6MT and Hamer95USA like this.
  12. Jul 13, 2018 at 1:24 PM
    yurtdweller
    @Glamisman
    I had the same question... So far, never burned oil that I can tell. Mechanic says that "because the entire exhaust is aftermarket, and placed in strange places, including the fact that the bung for the 02 sensors being in a different places from stock, and the welding jobs are poor" that it causes the computer system to trip the codes. And that further aftermarket parts will continue to trip codes because Toyota tolerances for differences in the system are very small.
    I also have a lot of rust in the rear tailpipe area, past the muffler. Haven't inspected up before the catalytic converters.. Both cats and both 02 sensors had to be replaced right after I drove it off the lot 2 years ago... the dealer took care of the first set, but the fact that they're bad again makes me want to scream. The small shop that did it did a really shit job the first time, threw more codes, I went and got a smoke test and there was smoke pouring out before the first cat. Took it back to the muffler shop and they cut it down and re-welded it and the code went away for some time.
  13. Jul 13, 2018 at 1:26 PM
    yurtdweller
    I just got a quote on the entire system from OEM..... Holy smokes. I can't spend that kind of money if there is something else out there that is stainless and cheaper and will work without throwing codes!
  14. Jul 13, 2018 at 3:38 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    Toyota parameters are tight on the ECU. He's right about that. It's not necessary to burn oil to kill a cat on these things, I've always blamed fuel (maybe wrongly).
    There are a lot of Toyo's with the CEL lights stuck on sold off to non emission areas because of the 'dreaded' codes.
  15. Jul 13, 2018 at 11:25 PM
    Luv my yota
    Luv my yota Well-Known Member
    00 turd lift 33's
    Kings,total chaos uppers, Deavers, JBA headers, Borla exhuast, engine mods, DC power 270 amp alt, 2k watts of sound, gps alarm.
    So much b.s. can destroy a cat therefore go with what passes and has a decent rep. I used a Magnaflow cat and couldn’t pass smog for the life of me!, bought a factory cat and she passes w/flying colors. I won’t ever spend on a factory cat again, walker has very good cats for 1/4 the price of factory and they pass just as the factory one will.
  16. Jul 14, 2018 at 1:37 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have been using Walker Exhaust systems for quite some time (100,000 miles or so)
    With no issues .
    If you have exhaust leaks between the Cats I can see it tripping a code
  17. Jul 14, 2018 at 11:21 AM
    Glamisman
    OP... that makes sense to me. Wrecking yard maybe unless you are in a rust state or it might be worth the drive to another state if you can find a decent exhaust there. What a pain in the rear.
  18. Jul 14, 2018 at 12:19 PM
    The Driver
    Raph
    If the catback for 4 cyl trucks and V6 trucks is the same, you can have mine, for the cost of shipping!
    FYI, I'm doing the headers and catback install in Sioux Falls, at a friends shop, so shipping would be from SD. Good luck!
    ClevSix likes this.
  19. Jul 14, 2018 at 12:34 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    If he doesn't want yours I'll take it. Might even drive to Sioux Falls to get it, LOL
  20. Jul 14, 2018 at 4:18 PM
    beemerphile
    beemerphile Active Member
    Lee
    Danielsville, GA
    04 Standard I4 Man
    Me too. Bought mine from NAPA. Cheap. Easy bolt up.
