Replacing entune plus with premium
Discussion in 'Audio & Video' started by PEPHOG19, Jul 25, 2019.
  1. Jul 25, 2019 at 5:36 PM
    PEPHOG19
    PEPHOG19 [OP] New Member
    Paul P.
    2019 Tacoma SR5 Extend Cab
    stock
    will a entune preumiun work in place of a entune xm sirus plus\standard. I have a 2019 Tacoma sr5. I bought a take out of a 2018 trd { not a JBL} and of course no bezel. off of ebay. has anyone done this to a sr5. and will the antenna on truck work with gps on premium????
  2. Jul 25, 2019 at 6:58 PM
    markmizzou
    markmizzou Well-Known Member
    Mark
    Missouri
    17 SR5 V6 4x4 AC AT tow pkg. Blue as they come
    A back step for when I get older, Carhartt seatcovers, 4Runner wheels, Topper, and "tats all folks"! --for now!!
    Read back on my past posts -- You will see it can be done. I did it!
  3. Jul 26, 2019 at 7:14 AM
    PEPHOG19
    Paul P.
    stock
    how do I go back to past post?
  4. Jul 26, 2019 at 9:49 AM
    Old one
    Old one Well-Known Member
    Dave
    2016 Silver Sky Tacoma SR5 Access Cab
    To answer your question, yes, there is the gps connection that just needs plugged in to the new premium radio. All plugs are the same on both radios and can only go on one way. Just pop off the bezel, remove 4 nuts that hold in the old radio. If you have XM activated, remove the XM module from the old radio and attach it to the new radio. For me, it was about a 20 minute job. Big improvement from the entune plus on the SR5, and have a working GPS. The only gotcha is you will need a new bezel for the larger radio. Price is between $200-$275.
    dolbytone likes this.
  5. Jul 27, 2019 at 9:18 PM
    markmizzou
    Mark
    Missouri
    click on my name you will see a category called "postings". Everything I have posted will be there. I was replacing mine about Dec 17 to early 18
  6. Aug 6, 2019 at 11:44 PM
    BearWithMe
    BearWithMe Well-Known Member
    Four Corners
    2025 OR 6MT Celestial Silver
    Prior: '18 OR 6MT
    You can easily trim your Entune Plus bezel to fit the larger Entune Premium headunit, if you're a little bit handy with a dremel. Take off a bit less material than you think you need to, then file/shave/sand the edges to get the opening large enough.
