Replacing factory bulbs in the cab w/LED
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nabdo92285x, Jun 10, 2016.
  1. Jun 10, 2016 at 6:53 PM
    nabdo92285x
    nabdo92285x [OP] Well-Known Member
    Nick
    '16 TRDOR PreRunner
    So I'm trying to replace those stock bulbs in the cab with some LED ones and I can't figure out how to get the original bulbs out, I got the cover off but my fingers are too big to actually grab the bulbs. Anyone tried this already and have a way to do it?
  2. Jun 10, 2016 at 6:56 PM
    BigE
    BigE Well-Known Member
    Eddie
    PNW
    14 MGM DCLB TRD sport
    check out my build page
    Subbed. Will be doing this soon as my bulbs come in ;)
  3. Jun 10, 2016 at 6:58 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    Are you referring to the main console? Pull the whole thing off by starting at the driver's side corner nearest the windshield and working counter clockwise. It comes off in seconds since there's only four pull tabs holding it up.
  4. Jun 10, 2016 at 6:59 PM
    Syndicate
    Syndicate Active Member
    2016 Black Tacoma DCSB TRD Sport
  5. Jun 10, 2016 at 6:59 PM
    pditty
    pditty Active Member
    Pat
    2016 TRD Sport
    I used a piece of duck tape and wrapped the old bulb around it to help grip it and pulled down
  6. Jun 10, 2016 at 7:00 PM
    psvines
    psvines Well-Known Member
    2016 SR5
    It's a delicate operation, I used a tiny flat screwdriver and very carefully pried them out.
  7. Jun 10, 2016 at 7:04 PM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Nailed it. Also when you install make sure it turns on. If it doesn't pull it out and reinstall 180 degrees. I just used some cheap blue smd ebay ones. They work great. I tried the red but they didn't put out enough light. I bought my dome from CSJumper I think.
