Replacing Factory Jack with something better
Discussion in '3rd Gen. Tacomas (2016-2023)' started by urchim, Apr 26, 2017.
  1. May 30, 2017 at 1:07 PM
    #41
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    just saying I got all the safejack attachments with an adaptor to fit the factory toyota jack and it works great.
    figure the screw type jack is less likely to fail than a hydraulic one should the temps get low etc and no need to worry about seals
    davidstacoma and TRDSport10 like this.
  2. May 30, 2017 at 1:21 PM
    #42
    ian2016
    ian2016 @shockteq
    2016 4x4
    Anyone ever tried one of these? Saw it on the home depot website and has decent reviews. Jack and jack stand in one. Seems like a cheaper option of the safe jack for about 60 dollars.
  3. May 30, 2017 at 1:46 PM
    #43
    SilverII
    SilverII Well-Known Member
    DFW
    2016 Tacoma Limited 4x4 Blue
    I have the powerbuilt version - probably made by the same chinaman. It works, but its not tall enough for my lifted truck. I have to use some thick boards to raise it high enough
    lynyrd3 likes this.
  4. May 30, 2017 at 1:49 PM
    #44
    ian2016
    ian2016 @shockteq
    2016 4x4
    Ah that makes sense. Thought it might be worth a shot but never mind.
  5. May 30, 2017 at 1:56 PM
    #45
    Joe23
    Like above I have it. It's ok. I bought it to try. Its handy but meh. Also to big to store in vehicle
  6. May 30, 2017 at 2:05 PM
    #46
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    I got one just like that from Tractor Supply for $40, very sturdy and the locking mechanism works great.
    https://www.tractorsupply.com/tsc/product/powerbuilt-3-ton-all-in-one-jack
  7. May 30, 2017 at 2:09 PM
    #47
    MilkTeacoma
    MilkTeacoma Well-Known Member
    I can't find it online. Do you have a link?
  8. May 30, 2017 at 2:16 PM
    #48
    lynyrd3
    Bill
    East Central Upstate NY
    Way too expensive for me , geezus !
    CusterFan likes this.
  9. May 30, 2017 at 2:27 PM
    #49
    herbertgerg
    herbertgerg Well-Known Member
    Gary
    1999 SR5 4x4 5spd Access Cab
  10. May 30, 2017 at 2:54 PM
    #50
    lynyrd3
    Bill
    How much lift do you have ?
  11. May 30, 2017 at 3:19 PM
    #51
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    This would of been a better idea. then the 3 ton jack I bought form harbor freight and the hitch mounted cargo carrier. to haul it around on our next road trip.
  12. May 30, 2017 at 3:20 PM
    #52
    Korndog1284
    Korndog1284 Well-Known Member
    J03l
    Washington
    2016 Off Road DCLB MGM
    All-Pro Raack Pack, Tepui Tent and Awning, ARB BP-51, K02 275/65/17, 4Runner Pro Wheels
    I was drooling over that at Overland Expo 2017!
  13. May 30, 2017 at 3:27 PM
    #53
    Milc
    Milc Hella Fun
    Orange County, CA
    2016 White DCSB TRD Off Road 4x4
    Popping the door open is a great tip. Thanks!
  14. May 30, 2017 at 3:41 PM
    #54
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    I like that. Specially when you're high speed jacking over rough terrain you need that skid plate. How much travel does it have?
  15. May 30, 2017 at 3:44 PM
    #55
    ian2016
    ian2016 @shockteq
    2016 4x4
  16. May 30, 2017 at 4:05 PM
    #56
    EarlJr
    EarlJr Member
    Raton, NM
    2009 Tacoma
    Stock
    Thank you for all the info. With the 2009 Tacoma screw jack I have the cap is a little larger than the shaft and the first shaft is a little skinnier than the second... like cap is 1-5/8, shafts are 1-3/8 & 1-1/2 approx. Are you using that kind of jack with the Safejack extensions? Have to remove the cap or use a sleeve around the thinner shaft?
  17. May 30, 2017 at 5:20 PM
    #57
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
  18. May 30, 2017 at 5:30 PM
    #58
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Yeah I'm going to do some measuring and figuring to see if it would go up under the axle if a tire was flat. I had a bottle jack in my '03 Dakota and it worked to rotate the tires but if you had a flat it would not go under the axle. No need buying it if that is the case with the Tacoma.
    https://www.amazon.com/Powerbuilt-620471-Unijack-6000-Capacity/dp/B00GJJZ5YC?th=1
    Probably a 2 ton would work better. CARid has the 2 ton cheaper.
    https://www.carid.com/powerbuilt/un...?view=901151&gclid=CIHn-oTQm9QCFQeOaQodYCcGtw
  19. May 30, 2017 at 5:38 PM
    #59
    neegra
    neegra Well-Known Member
    GA
    2016 DCSBTRDOR4x4
    EDIT: Read the thread a little better, and looks like Scooter found the best link so far :cool:
    This one looks different, but same brand and not from Amazon.
    Pep boys currently has it for $44.99. I have two of these in the garage, and so far so good. I bought mine during a better sale, but it wasn't too much more off.:thumbsup:
    https://www.pepboys.com/product/details/633527/00044
    CusterFan[QUOTED] and ian2016 like this.
  20. May 30, 2017 at 7:25 PM
    #60
    FrankJake
    FrankJake Well-Known Member
    Southern California
    2017 Tacoma TRD OR SB Magnetic Grey Metalic JBL Stock (so far)
    Shift Sense Pro, HomeLink Mirror, Screen Protector, Tinted Windows, Now onto the expensive stuff
    Someone else mentioned, get a bottle jack and a block of wood. The jack can fit under the rear seat. A 2x10 or 2x12 cut into a square will be fine to stabilize the jack. If your looking for something for changing a tire on the highway, you probably don't need a block. If off roading, you should take a few blocks. They can come in handy. If you heavy off roading, high lift jack. It kind of depends what you plan on using it fir the most. Sometimes if you get stuck, you need more than a jack.
