Replacing front brakes pads
Discussion in 'General Tacoma Talk' started by jplii, Oct 8, 2024.
  1. Oct 8, 2024 at 2:08 PM
    jplii
    jplii [OP] Member
    2019 Tacoma Sport
    I've watched several YouTube videos about replacing front brake pads without removing the calipers. I've done this in the past on other vehicles but have always removed the cap on the master cylinder before compressing the brake pistons to allow room for the new pads. In none of the videos I've watched do any of them mention removing the cap on the master cylinder. Is this necessary or just an old wives tail?
    HondaGM likes this.
  2. Oct 8, 2024 at 2:10 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I never have...
    wilcam47 and Kwikvette like this.
  3. Oct 8, 2024 at 2:18 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    Probably not needed in these but I open it anyway since I flush the fluid when I change pads.
    wilcam47 and HondaGM like this.
  4. Oct 10, 2024 at 7:57 AM
    JFriday1
    JFriday1 Well-Known Member
    Jesse
    Lakewood, CO
    19 Taco TRD-Sport, 16 4Runner
    Mobile Mechanic in Denver Instagram - "Jfriday123"
    I do it as a common practice.
    I also remove the calipers bc its easier to compress the pistons back with the proper tool. If you turn the wheels then you can zip the two bolts off with an impact.
    Make sure you replace the slides and get some anti-squeel paste for the back of the pads too.
    MadNachos and jplii[OP] like this.
  5. Oct 10, 2024 at 8:01 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Also never have needed to open the reservoir cap to change pads.
    But with that said, unless I'm swapping out fresh pads for something else because I didn't like them, I generally change the rotors and pads together and flush the fluid out at the same time.
    MadNachos likes this.
