Replacing Front Brakes
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ADKBackwoods, Sep 19, 2020.
  1. Sep 19, 2020 at 3:52 PM
    ADKBackwoods
    ADKBackwoods [OP] Member
    2016 Tacoma TRD OR MGM
    I found a few posts with descriptions on how to replace the front rotors and pads but I am wondering which is the best or most complete set of directions. Looking for the best set as I have not done my breaks yet. Appreciate the recommendations.
  2. Sep 19, 2020 at 4:08 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
  3. Sep 19, 2020 at 4:08 PM
    DaBigDogg
    DaBigDogg "Say when..."
    Jay
    Mid-Suffolk, LINY
    2024 Celestial Silver DCSB TRD OR Hybrid
    Have you done brakes on any other vehicle? To my knowledge there isn't anything special about the front brakes on our trucks...
    Skydvrr and Gunshot-6A like this.
  4. Sep 19, 2020 at 4:12 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    It’s fairly easy to do. Just remember to remove the bolt that hold the brake line to the strut and don’t hang the caliper bracket with the brake line or you will tear it. And make sure you push all 4 pistons at the same time in the caliper bracket. If you only squeeze one side the other side will push out and you are going to leak brake fluid.
  5. Sep 19, 2020 at 4:28 PM
    ADKBackwoods
    I have not done breaks before but I am not without some skill and I heard that it wasn't a hard job so I thought I would give it a go.
    Appreciate the tips as well!
  6. Sep 19, 2020 at 4:36 PM
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    Gotcha. Try this video. I like it because it does mention using the screw holes to unstick a rotor.
    https://www.youtube.com/watch?v=FLiedgXMxXs
    BT17 likes this.
  7. Sep 19, 2020 at 4:46 PM
    ADKBackwoods
    Appreciate the video. Seem simple enough.
  8. Sep 19, 2020 at 6:01 PM
    DaBigDogg
    Jay
    Mid-Suffolk, LINY
    Just take your time, use your phone and take pictures (in case you lose track of where things go) and see if you can enlist the help of somebody with experience
  9. Sep 19, 2020 at 6:05 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    how many miles are on the original brakes, may just need new pads
    LilTexan22 and Tacospike like this.
  10. Sep 20, 2020 at 3:41 AM
    ADKBackwoods
    I have 71k on them now. I have been getting a clicking sound when I apply the brakes for the first time after switching from forward to reverse or the other way. I am 99% sure the pads are are slapping are shifting back and forth and hitting the caliper because they are worn out.
    I have never had just pads replaced without having the rotors being done at the same time. Is that an acceptable practice?
  11. Sep 20, 2020 at 3:55 AM
    BillsSR5
    bill
    2014 SR5
    yes
    Tacospike likes this.
  12. Sep 20, 2020 at 4:58 AM
    mexanese.502
    mexanese.502 Well-Known Member
    Kentucky
    2017 Limited BADASSMF
    OV Tuned
    My two cents as I wake up. Wouldn't use a torque wrench to break off lugs, and were are the dust caps for the axle nut.
  13. Sep 20, 2020 at 9:49 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Check your rotor thickness with a micrometer or caliper to ensure they are not under minimum thickness. As long as the rotors are in spec and you are not getting a pulsing in the pedal is is ok to just put on new pads.
    just make sure you use good parts... not the Chicom crap from the local auto parts store. EBC makes great rotors and pads.
  14. Sep 20, 2020 at 10:16 AM
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    make sure your brake master cylinder is not full of fluid. When you press the caliper pistons in, it will force brake fluid from the calipers up into the master cylinder and may spill out which is bad, brake fluid is very corrosive and will eat paint. If you have to, use a small turkey baster to suck some of the fluid out of the master cylinder before you start.
  15. Sep 20, 2020 at 1:19 PM
    LilTexan22
    LilTexan22 Well-Known Member
    2017 Tacoma
    I replaced my brakes pads at 50k miles. I used the same rotors and did not get it resurfaced because they were still good. I have 80k miles now and the front brakes have been working perfectly no squeals or abnormal wear.
