Replacing Front Breaks ONLY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LP_Y_SO_SRS, Feb 29, 2016.
  1. Feb 29, 2016 at 1:16 PM
    LP_Y_SO_SRS
    LP_Y_SO_SRS [OP] Active Member
    Luis
    None yet
    Tried search was not able to find anything specify.
    So 35k miles on my truck and front breaks are down to nothing.
    Should i replace my drum breaks seams like the drums breaks should last upwards of 60k miles rights?
  2. Feb 29, 2016 at 1:19 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    are you heavy braking all the time? Seems pretty low miles for needing brake pads. Usually front pads go quicker than rear shoes...
  3. Feb 29, 2016 at 1:20 PM
    07Speedway4X4
    07Speedway4X4 Active Member
    Seattle, WA
    2007 SWB AC 4WD TRD Sport
    Bilstein 5100's set at 2.5 w/ 1.5" block in rear ATX Mojave II 17x8 with Wrangler DuraTracs
    The first time I replaced my pads was at 64k miles and I still haven't replaced the drums/shoes and I'm at 120k.
    LP_Y_SO_SRS[OP] likes this.
  4. Feb 29, 2016 at 1:22 PM
    LP_Y_SO_SRS
    Luis
    None yet
    I guess so, iam pretty hard on the brakes, do you replace breaks all at one time or do you space out having the front and rear done seperatly?
  5. Feb 29, 2016 at 1:22 PM
    Thomas Jefferson
    Thomas Jefferson Keyboard Warrior
    Sacramento,CA
    '13 SR5 DCSB 4x4
    One can never have too many light bars.
    The drums should last a very long time. With that said I would check them because replacing the fronts at 30K is quick. My truck has 40K on it and I still have about half of my stock front pads left.
  6. Feb 29, 2016 at 1:23 PM
    Styx586
    Styx586 Well-Known Member
    Terrance
    Lake Elsinore, Ca
    2013 Tacoma DCLB TRD Sport, 2001 Tacoma TRD Off-Road
    You don't have to change the rears at the same time as the fronts... If your fronts are worn, just replace em. Rear drums should last you like 100k miles.
  7. Feb 29, 2016 at 1:27 PM
    wilcam47
    Will
    Bourbon state
    depends on your driving habits and or if you rest your foot on the brake pedal while driving....yes Ive known and seen people driving around with their foot on the pedal:eek: and they wonder why their brakes go out so quick.
    typically all disc brakes replace at the same time...if you have pads in the front and drum rear you'll typically replace 2 front sets to 1 rear shoes.
  8. Feb 29, 2016 at 1:47 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    replace axles at a time. that is, front breaks at once, or rear at once. You dont need to do all 4. Honestly the rear drums n shoes will last like 200k miles. (dads 04 taco still had life left in the shoes at 220k)
  9. Feb 29, 2016 at 1:47 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    great googly moogly
    procedure to answer the question
    get the rear drums off
    measure pad thickness on both sides
    on both ends of pads
    and measure
    drum thickness
    do they need replacement tor not ?
  10. Feb 29, 2016 at 1:55 PM
    stphnman20
    stphnman20 Well-Known Member
    SCV
    2016 T4R
    Yea 35k is low. I have about 46k on mine and it's still about half way.
    Plenty of vids on youtube on how to change brakes on a Tacoma.
  11. Feb 29, 2016 at 2:09 PM
    balljoint
    balljoint Well-Known Member
    Dave
    Ontario
    '18 DCLB
    What year is the truck? Is this mileage from brand new? Or from new to you? Or from b r a k e pad change from parts store pads?
  12. Feb 29, 2016 at 2:14 PM
    LP_Y_SO_SRS
    Luis
    None yet
    2013 bought it used back in june
  13. Feb 29, 2016 at 7:32 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    I just did the fronts on mine for the second time and 136k on the clock. Rear drums are still in good shape.
  14. Mar 1, 2016 at 6:45 AM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    The rule of thumb I have used down through the years is that you change the fronts about 3 times before having to change the rears
  15. Mar 1, 2016 at 7:08 AM
    wade9986
    wade9986 Well-Known Member
    Ross
    Stuart, Florida
    2020 TRD Sport 4x4 Supercharged
    Magnuson Supercharger OTT Tune TRD Pro Front End Conversion Old Man Emu Lift 285/70/17 Nitto Trail Grapplers 17x8.5 Black Rhino Duggers Fab Fours Front Bumper Smittybilt X20 Winch Rigid Industries Lightbar
    Inspect the drums to be sure, but usually it is not needed for many many miles. My original front pads lasted over 90k miles. I didn't even check the drums yet. I'll check them next time I need front pads.
  16. Mar 1, 2016 at 7:18 AM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    The rear Will outlast the front 3 folds, 265k on oem rear shoes.
