Replacing front bumper face bar...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Backinblack03, Mar 13, 2015.
  1. Mar 13, 2015 at 2:19 PM
    Backinblack03
    Backinblack03 [OP] Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS sucks.
    I have a short window of opportunity to change out my rusted chrome front facebar tomorrow. How much time is typically needed to swap it out with hand tools? If I can't finish it, I shouldn't start it...
    Thanks!
    Fuergrissa likes this.
  2. Mar 13, 2015 at 5:09 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    There isnt a lot to it, a couple brackets holding it to the frame. Just have to swap the lower plastic valence too.
  3. Mar 13, 2015 at 7:04 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Took me about 1 to 2 hours. Straight forward job nothing tricky
  4. Jun 20, 2017 at 7:53 PM
    Ecnerwal
    Ecnerwal Well-Known Member
    NW Mass
    '02 4x4 2.7 A/T Ext Cab
    gradually replacing the bumper with hairy bondo ;-)
    Elderly thread, I suppose you could follow it up yourself by now...
    Given it's rusted, short window of opportunity would not be a good match, in my experience (not over yet, taking a break.) Folks from areas with "cosmetic" rust or "what's rust?" can probably do it quickly. I started putting penetrating oil on the mounting bolts 4 days ago, and only got the expletive thing off today, since the Left side mounting bolts were frozen but good - took a couple sessions with a propane torch before they budged, and one left its threads in the nut at that. Hammer-driven impact driver wouldn't budge them.
    Now that it's off the truck, getting the plastics off the facebar to put on the new facebar is going to be a tedious pain involving an angle grinder, as about 2 of them were actually able to be unscrewed. The rest are shapeless lumps that won't simply fall off, but can't be grabbed with a wrench or vise grips. Then it will be trip to the stainless steel section at the hardware store, as this is obviously something Toyota does poorly, at least for my area, so the Toyota parts won't be getting bought for it. I guess a can of undercoating might be a wise investment as well.
  5. Jun 21, 2017 at 4:27 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    I did mine some years ago, and had similar issues. The non-chome replacement was plasti-dipped both sides. It's holding up well.
  6. Jun 21, 2017 at 10:21 AM
    Thad
    Thad Well-Known Member
    Thad
    Pittsburgh
    2004 Tacoma
    Your gonna find rust you never expected to find. I did mine and wish I would have just bought the kit with all the little clips and stuff. would a been way easier than working around all the rust I encountered.
  7. Jun 21, 2017 at 2:26 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Old thread but my last project like that has now been going on since Hurricane Sandy
