Replacing front pipe
Discussion in 'Performance and Tuning' started by Jmannrt, Dec 2, 2012.
  1. Dec 2, 2012 at 6:40 PM
    Jmannrt
    Jmannrt [OP] New Member
    Mississippi
    95.5 Tacoma Herculined
    3"body lift, 3" suspension lift, 35x12.50 BFG M/T KM2s on Mickey Thompson 15x10 Classic IIs, Flowmaster muffler, Magnaflow high flow cat, K&N intake, throttle body spacer, Hella lights, brush guard, nerf bars and Herculiner paint job. (All done myself).
    New to the forum deal so ill shoot a question out there... Got a 1995.5 tacoma 2.7L 4x4. Im wanting to replace my front pipe coming down from my manifold because it no longer sits flush enough with the manifold to keep a seal( bad flange im assuming)Ive tried new gaskets and putty several times and nothing works. Out of all the pipes ive looked at online, they all have an O2 sensor mount right at the glange but my pipe doesnt have one there ( mine is further down on the intermediate pipe. Any one else fun into this problem? Is there another year this pipe is found under?? Thanks yall
  2. Dec 3, 2012 at 5:48 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    As long as your sensor can reach the spot on the new exhaust, you will be just fine. Post up some pictures to the exhaust components you are looking up, or links to them. That will help.
