Replacing front struts
Discussion in '1st Gen. Tacomas (1995-2004)' started by tullymars, Jan 7, 2011.
  1. Jan 7, 2011 at 5:05 PM
    tullymars
    tullymars [OP] New Member
    Bethlehem,Ga.
    2000 prerunner 2.7 2wd
    Im replacing the shocks on my 2000 prerunner,the front appear to be struts,question:Do I replace them like regular struts meaning I need a spring compressor,or can I unbolt the the top of the strut rod and the lower part from the lower controlarm and slide the cartridge out?
    Thanx in advance,Tully
  2. Jan 7, 2011 at 5:15 PM
    NegroTundra
    NegroTundra Well-Known Member
    Land of Enchantment
    03 Tacoma TRD 4WD 5 spd
    Holy smokes you got a lot to learn....do a search.
    Short answer (suppose I will be the enabler):
    1) Buy new SHOCKS
    2) Remove coilovers from truck....three 14mm nuts on top (do not touch middle nut) and one bolt on bottom connecting to lower control arm.
    3) Take your coilovers and new shocks to spring shop and have them swap them, shouldn't be more than $40
    4)Reinstall
    5)Alignment
  3. Jan 7, 2011 at 5:16 PM
    joeer77
    joeer77 Active Member
    North Plains OR
    Bilstein 5100s
    The struts are preloaded so you need to rent a spring compressor. You can rent one for free from autozone with a $50 deposit. I recommned having a air compressor and impact wrench to run the compressor. Make sure your spray oil on the compressor as you use it. Mark the spring with paint so you keep the orientation the same when you put in on the truck with the new strut.
  4. Jan 7, 2011 at 5:16 PM
    tullymars
    Bethlehem,Ga.
    Never mind,crawled under her and realized they're basically just struts,so I'll get a spring compressor tomorow:rolleyes:
  5. Jan 7, 2011 at 5:18 PM
    joeer77
    North Plains OR
    Bilstein 5100s
    Also you should read the factory service manual. It explains exactly how to remove and reinstall the struts with the proper torque values. You can download the manaul online for free if you search.
